i am wrecking a r33 gts-t. it is a silver 1996 model.
call John; 0432-568-279
interier;
- drivers seat $50
-passenger seat $50
-back seat $100
-seat belt harness set $150
-full interior plastics
-dash
-etc
exterior
-rear tail lights pair $150 (can seperate)
-back bumper $100
-stock suspention set $150
-tail shaft $150
-diff $80
-rear window $40
-doors complete with windows $100each
-rear wipers $15
-rear view mirrors $30 each
-petrol cap $10
-stock side skirts $40 each
-etc
performace
-3.5 inch hks exhaust from start 2 end $350
-stock r33 intercooler with piping $150
-etc
https://www.sau.com.au/forums/topic/293640-r33-wrecking/
Hey mate,
Do ya still have all interior stuff?
I'm looking for a Series2 dash surround plus matching gear stick surround/ash tray.
Also, what rear spoiler did you have on it?
Any pics would be great.
Cheers.
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4927819
Hello,
I'm interested in the side skirts, and back bumper, possibly the exhaust also.
Please let me know what area your from and if i'm able to come look at the parts asap :)
Thanks, Daniela.
interier;
- drivers seat $50
-passenger seat $50
-back seat $100
-dash
-etc
exterior
-back bumper $100
-tail shaft $150
-diff $80
-rear window $40
-rear wipers $15
-petrol cap $10
-etc
performace
-etc
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4928454
Does that refer to the wing mirrors. If so I would be happy to take the passenger side wing mirror.
its the rear view miror. but if u want door mirrrors i have them 100 for both
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4946879
hey mate.
how much for the radiator support panel? am happy to remove it, if you cant be bothered.
can provide picture of what i want if need also.
thanks
andrew
the front end it dammaged . so radiator support pannel is buggered
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4946885
Hey mate,
Cheers.
i have all that stuf. but it is off a series 1. i installed all series2 on mi own vehicle.
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4946893
Hello,
Please let me know what area your from and if i'm able to come look at the parts asap :D
Thanks, Daniela.
northern suburbs. melbourne call me 4 more info 0432-568-279
https://www.sau.com.au/forums/topic/293640-r33-wrecking/#findComment-4946898
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
