Hey guys, I gave this a quick search, though I wasn't sure as to what forums I'd find an answer in, nor was I sure what to search for exactly lol.
This is (as of about 6 months ago) my car:
http://www.skylinesaustralia.com/forums/R3...ht-t242518.html
That FS thread gives a decent list of all current mods/parts on the car, and the only things I've done to it since I got it is steering component replacements (tie rod ends etc) and all exhaust gaskets from the manifold back. No performance upgrades.
Now that I've had those 2 repairs done it it, I'm looking to build it up a little. Currently making 167.7rwkw @ 11psi on a mainline dyno.
Unfortunately due to my inexperience with modifying cars, I'm unsure what do start with. I have a good idea on what to do overall, but not what to do first. This is where I'm hoping some of you guys can help out a little :(
As the car is technically a daily until probably around March next year (when I move out after overseas trip), I don't want to go TOO far and have something that's not worth putting the kms onto. I'd like to aim for anywhere between 220rwkw - 250rwkw until this time.
Any suggestions as to where NOT to start would also be much appreciate if you can't put in any input as to what to do first :(
Thanks guys :D
https://www.sau.com.au/forums/topic/293715-looking-to-begin-further-mods/
Oh? Interesting. I'd thought maybe a little more than that would be needed, but that's probably good! What kind of $$$ am I looking at for something like a Vipec? And any particular brand for injectors?
sard or nismo injectors and a Vipec or second hand PFC and a tune and you'll get 230-250rwkw no probs. So around $2.5-3K and your there. Not sure about the exhaust either?
But easy mods really.
  • 1 month later...
ok so bumping my thread...I haven't had the time to organise any mods as yet, but after having it run on the dyno to investigate a few odd engine sounds that only appear under load (gas leak sound ~2400rpm, whistle sound ~3500 - 5000rpm) and being told that the mechanic couldn't replicate any of the sounds, but not to worry about them as they won't be something vital (ie. cat could be bung, BOV could be leaking under full boost)...
The upside of this dyno run is that the CAS was out, causing retarded timing. Not sure how many degrees it was out by, but after lining it up correctly, the car made 190.8rwkw @ 184kp/h - like I said, same mods as above...
Any rough ideas on what power figure I could achieve with Injectors, pump, and Nistune? Still aiming for 230-250rwkw, but after having seen power increases from some other people's runs, I got no idea what to expect haha
Thanks again oh-knowledgable ones :)
  • 3 weeks later...
Hey troy, as it was my car, and I had the same thoughts as you, I was told to go with a decent set of injectors and ecu.. Rb25 AFM's work well for the power you are wanting to acheive, so I would suggest a Power FC, they are readily available second hand, and they are a cake-walk to install and tune.
Therefore my suggestion would be in this order.
Power fc
Injectors
Full service
Tune
See where youre at when this all goes down and you should be good for what your chasing.
Then stage two would be imo.
Turbo upgrade
Cooling system revised, including radiator, and oil cooler
Air intake system revised, AFM and CAI
Re-tune
This would see the car becoming quite a scary and fun little street car for what it is..
Really it all comes down to the specs of that highflow turbo and what power it will make. Any information on what company highflowed it? Will give you a better indication of what power it will most likely make and how far you can push it.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
