Driving home from work tonight, the GTR started making a noise I havent heard before. From inside it sounds to be coming from the rear of the car like the exhaust is slightly bouncing up and down knocking into the metal frame. It only occurs while decelerating but its repetition is timed with the speed of the car so the faster I'm going the more often the noise goes. Almost like something builds up momentum and bounces up and down. It may also occur over bumps but the R33 is so loud I cant quite tell (and my hearing is subject to the placebo effect). The noise does not occur while accelerating or under brakes, gears and clutch position were irrelevant.
I jacked it up and started wobbling things trying to work it out but haven't found anything obvious enough to trigger my limited mechanical skills. Looked in the wheel arches for anything rubbing or stuck to the wheels but no. Checked all fluids levels were ok, nothing leaking (except airconditioning condensation), no eccesive knocking showing on the powerfc...
It's loud enough to concern me, I'm sure people driving next to me can hear it.
Any ideas?
Edited by Joshdc
https://www.sau.com.au/forums/topic/294230-rear-end-knocking-noise/
Any ideas?
do you have adjustable rear upper control arms? mine are noisy compared to the stock bushs+control arm
-D
-D
Stock arms as far as I know, the bushs arent stock, but that was changed wtih the suspension a few months ago and hasnt made the noise before.
I was thinking Diff as well!!!
Happened the the cef one day, was driving on one day n the diff was noisy! and then it got noisier then it went bang as i was doin a Ubolt! after had really loud bangs on excleration and deceleration the faster i went the quicker the bangs! Checked it out as i crawled home (everyone stareing) And found the diff was f**ked. Had to go out n buy a new diff
1.5 way LSD :P
Edited by MYCEF3
Yeah same i hope it isnt the diff as well!
If its youv looked at all the exhaust, coilies and other stuff that could knock or hit, the other is the diff (only coz the banging ur hearing)
Edited by MYCEF3
  • 5 months later...
Woops I forgot to post the resolution.
Luckily I found the source before I lost a wheel...
Turns out i am an idiot and didnt tighten a couple of wheel nuts properly. Caused this noise for a good week of driving - all good now though.
Thanks every for the suggestions.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
