Just installed a Profec B into my R34 GTR, and stuck on the last part. T'd the actuators into the new solenoid, blocked one hose off the factory solenoid, and blocked both plenum pressure outlets on the passenger side (found it much easier then digging in under the inlet mani). However, there are no fittings on the comp housings or hot side intercooler piping to get a reliable pressure source for the solenoid. What does everyone usually do? Take the factory source from the plenum, or drill and tap a fitting on the hot side "twin turbo" pipe? Would love to hear some options.
Tried searching but the function on this board is sooo vague at times..
Also taking suggestions on mounting the unit on the underside of the dash, double-sided tape keeps coming loose :D
https://www.sau.com.au/forums/topic/294461-pressure-source-ebc-install/
I'd stay away from sourcing it from the inlet mani/post throttle body.
Cos in a situation of say half throttle when your on boost, you signal wont read what the turbo is actually putting out.
Under half throttle the turbo will need to spool up more than say 10psi, for 10psi to reach the source...
I'd say find a good spot (reasonably close to the throttle body) and drill and put a hose barb.
And for f**ks sake, make sure its sealed. Some gasket maker should to the trick, better still, get a stainless hosebarb and weld it onto a bit of steel piping, the cross-over pipe to be exact... Don't use the hot side, its not very accurate (hot air = less dense = less pressure)
Happy boosting...
Ok. On an RB26 the inlet mani is pre-throttle bodies, so that would be close to the throttle bodies without being post, as you were suggesting. There is no crossover pipe either like other RB's.
In all my previous turbo cars i have always put a barb on the hot side, because i was always under the impression that it is better to be as close to the comp housing as possible.. I maybe totally wrong, but thanks for the feedback :(
woops didnt see it was a GTR...
yeh doesnt really matter hotside vs. cold side, in the end doesnt make THAT much difference...
Plus taking it from the cold side allows for any tiny leaks in the cooler piping, and youl get that tiny bit more boost out of it.
I've always thought its more accurate cos closer to the TB(s) gives the signal of exactly the pressure that's going into the engine
But yeh, doesnt make a huuuge difference...
As for mounting it, try drilling two little holes in the plastic, then feed a cable tie through and around the controller. Thats if your cool with having 2 little holes in your dash that is...
lol, that's actually what i thought about doing! Might use velcro though as R34 dash parts maybe a lil $$$ to replace.
does a profec b have 2 or 3 lines you plumb into engine ? you called it a pressure source . meaning where the pressure supply to open the waste gates comes from . or did you mean the signal line that actually tells the boost controller how much boost is on the intake manifold ? . reading your post i think you did and turbo x trail has the wrong idea about what you wanted
Sorry not sure if i had the right term or not, that's why i tried to describe it.
The Profec has a vacuum source which runs directly to the control unit inside the car. It has another line that runs from the solenoid, which i have t'd both actuators into.
The final line is meant to run from the solenoid to the compressor housing or hot pipe according to the instructions. That is the one which i would like an opinion on.
just use whatever line was going to your actuator before, put the T piece on it and run one line to your solenoid and the other to the profec, done. using the intake manifold for the pressure source is fine, everyone says you cant and it'll never control boost properly but i've never seen it not work perfectly
I heard that i shouldn't take it from the intake mani too, but it makes sense that you can... Perfect, exactly what i wanted to hear! Thanks dude.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
