Hay!
Im Mitch , and i dont own a chaser.
this is my Nissan Skyline R33 GTS-T S1 M-Spec
Modifications.
Engine:
*rb26dett conversion
*rb26 sump with transfer case sliced off
*rb25 engine mounts
*rb25 Harmonic balancer
*HKS Intercooler
*HKS Pod filters
*Blitz 80mm stainless steel tuned front pipes
*Signal stainless steel straight through with carbon muffler
*Splitfire coil packs
*Toda Racing clutch
*Toda Racing 4.5kg Flywheel
*Cusco 2 way mech diff
*Iridium spark plugs
*R33 GTR fuel pump
Suspension and Braking:
*Selby rear 28mm sway bar
*Racing Gear coilovers
*D1 rear camber arms
*D1 hicas lock bar
*D1 adj castor rods
*Cusco front tension rod
*Solid rear sub frame bushes
*Project mu slotted front rotors
*TRW pads all round
*Nismo front strut brace with brake stopper
*GTR rear strut brace
Bodywork:
*Full body respray
*Satin Black bonnet and wing
*Sparco bonnet pins
*Nardi steering wheel
*Trust/GreX gear knob
*Sparco Spirnt drivers seat with Bride super low rail
*GReddy Profec B Spec II boost controller
*GReddy turbo timer
*GTR centre gauges
*GReddy boost gauge
Oils I Use & Recommend
*Castrol Edge 5w30
*Redline shock proof diff oil
*Redline shock proof gearbox oil
*Redline powersteering fluid
*MOTUL 600R brake fluid
A Week After It Getting Dyno'd The Motor, It Spun a Bearing Which Sucked
So Let It Sit For a Couple Months And Then Thought , Screw It, I'm Ripping This Engine Out
So The Stripping Begins
Started By Taking Turbo Piping Out
in between not having an income or anything to do i decided to do some minor shit on the car
started by removing some crap out of the boot and painted it all black
next was the rad support , it got a bit bent getting the rb26dett out so i hammered it back into shape as best as i could and then thought stuff it , and took off the jdm concept and cusco sticker to obtain a neater look
got the stickers off and lightly sanded the rad back a bit to remove marks and touched it up with some more gloss black
after selling all my GTR parts and winning $1k at the casino i bought a new motor , decided to get one off SAU as it was cheap and had new gaskets all through it
then i found this haha
went and hit up nissan from some overnight parts from japan (Not really overnight , they were in stock )
bolted everything onto it and it started looking complete! :D
then went out and bought all the stuff i was in need of
also decided to splash out a couple hundred and get a good front pipe as my GTR one was useless to me with a 25det
after i got all this and took note of the engine diagrams i had i realised i was missing a
tensioner pulley and an idler pulley , not to mention a water pump pulley !
so, dropped it all in
after alot of messing around i finally got the gearbox to line up nice and snug !
after a lot of messing around in to the early hours of the night hooking up remaining hoses such as breathers on the turbo
and replacing the throttle cable, which required removing my sparco seat and getting my mate to crawl under the dash to do so haha!
hooked up a stock side-mount for the time being as i cant afford piping
for my HKS core and i just need to get it running.
also bought a HKS sus power air filter panel for better induction but i think im just gonna run a pod for now.
here are some more pics
was heaps fun pushing it onto a car trailer at 8am in the morning!
continues on next post
https://www.sau.com.au/forums/topic/294477-my-r33-gtst/
  • Replies 92
winch was useless haha
and finally , its in (thats what she said)
i like the look of it from the back
after the car being in the workshop for a week i decided to wonder down there as i hadnt heard anything from them..
came to find out they got broken into and my car had stuff missing...
i started freaking out because i wasnt allowed to inspect my car as the police hadnt arrived to fingerprint the scene etc etc...
i had to come back the next day, what a frigging painful 24 hours that was!
anyways went down there the next day , opened my door on the car and was confronted with this...
missing: JVC fold out tv & greddy profec bspec 2 ebc.
NOT HAPPY
and to add to the frustration its not covered by the workshops insurance (already went through all the legal bullshit and i decided to give up)
so now im out of pocket close to $2k including a new dash surround...
and then i find out my rb25det has a blown piston and bent valves!
im sick of the car , all i want to do is skid it already!
so, the workshop told me the engine has bent valves and a blown piston.
this didn't sound right to me as the engine i bought was low km and had new gaskets all round and had the head cleaned up.
so i decided to pull the head off so that i know for certain.
anyways i got the head off and there seems to be no visible bent valves what so ever. after having my 26 head that had bent valves i have an idea on what to look for and i also had an apprentice mechanic mate have a look over it and he said that they don't seem bent. next step is taking it to an engine builder and getting it vacuum tested and going from there.
just from pulling it apart you can see how clean the head is.
turns out they were wrong, they put the bolt into the cam pulley too tight and didnt put a spring behind it making the cam not turn at all, and well what do you know , cylinder 3 is OPEN like a homeless shelter on Christmas day...
got my mechanic to look over it aswell and he did a test on it and there arent bent valves...
fkd if i know what that workshop were doing but clearly they were wrong.
started cleaning the head up where the old gasket was and also started cleaning the valves up .
finished the cylinder head off!
bought new cam shaft oil seals from Nissan as they were missing, re lubed camshafts as one was seized up.
so , i was browsing some forums just sussing parts for my car and i came across this
series 2 r33 gtst auto
was in Victoria but i didnt care , was going down there for the grandfinal anyways!
turns out it was 1 street over from my cousins and his mrs knows of the owner and said that he
always respected his cars and always was maintaining them.
spoke to the kid who owned it and he was a champ
had a good look over the car and worked out whether it would be viable or not , decided i wanted it so i paid him a deposit!
went back down the following weekend as i had a 50th birthday to go to , picked it up on the Sunday and towed it to my cousins place ;)
https://www.sau.com.au/forums/topic/294477-my-r33-gtst/#findComment-4918356
and surprisingly my parents don't care about me having another skyline in the driveway haha , i think its cause they know this is the last of the troubles !
so , i decided to drive down there with my dad and a car trailer to pick it up
but this plan failed epicly
i cant be stuffed re-writing it so here is a direct copy paste from my facebook from when it happened !
what a shit past 24 hours ive had !
set off from home yesterday morning at 7am to get a car trailer to go to vic to pick up my white R33,
we got to stirling and there was smoke coming out from under the car, looked to be coming from where the headers join the exhaust so i assumed it had blown an exhaust gasket..
continued up the highway towards tailem bend and it was still smoking but was driving fine, pulled up for some lunch and continued driving.
got to coomandook and jacked the car up in a way side stop , checked the tranmission out and it was roasting. let it cool down for a bit and kept going after checking all the lines to it
ended up getting 10km out of kiki and the car gave up, needed transmission fluid bad!
i remembered when passing kiki there was a garage there so we started the 10km hike back there to see if they had fluid, got there, garage was shut !
luckily a women that lived next to it offered us a lift to the next town which was yumali.
got there and bought 2x 1L ATF top up bottles , the women that gave us a ride told the store owner what had happened and he ended up giving us a lift back to our car thankfully !
got back and started jacking the car up , took one of the lines off for the trans and started bleeding in the ATF, took for ever to do but we got about a good 1 or 2 L in to it , went to try it and nothing
car still wouldnt even move!
let it sit for a good 30 mins and it started to move along so we crept along the highway towards coonalpyn, got into coonalpyn about 4pm and found a mechanics that was open but he couldnt help us,
all he said he could do is sell us some fluid.
ended up buying a 4L bottle of ATF and then bleeded most of it into the trans. didn't do much , got the car moving once again and decided to head back towards adelaide!
ended up getting about 10km out again and bam , nothing at all.
by this time it was 8:40pm , we thought there's no way we can sleep here and there's no way we can get home so we walked back to coonalpyn.
got back there at about 9:40pm and went into the pub , spoke to some of the locals and ended up getting towed back into the town.
at this point we hadn't eaten since breakfast and had pushed the car pretty much 5km with a big car trailer on the back of it , i was f**ked and couldn't give a shit , i needed sleep!
ended up getting a room at the coonalpyn pub and all the bloke wanted for dragging the car into town was a scooner so i bought him a couple of rounds.
decided to hit the hay and work out the car tomorrow.
woke up at 9am and packed our stuff to go back to the car, thought oh yeah might aswell see if the thing will move but nope wouldn't move,
by this stage id spent roughly $80 on fluid and $80 on getting a room , not to mention trailer hire and fuel costs.
my mum ended up calling so i got her to check my netbank to see how much i had left , had about $300 which was good to hear , rang a tow truck company in tailem bend and they said $500 to get back to my house with the trailer,
i said yep great let me get $200 together and ill call you back, my dad rang his sister in melbourne and she transferred $200 into his account and rang the tow truck, after about 1 hour he showed up, boy was i glad to see him !
loaded the car up and hooked the trailer on the back and started the journey back to adelaide, at this point i was tired, sore, sunburnt and broke , i really couldnt give a shit what had to be done , just take me home!
ended up getting back home about 1 hour ago
f**k im glad im home now , im wrecked , not just physically :(
oh and our phones are disconnected so we couldn't make calls !
all of this head f**k to get my other car
FML !
anyways , got the car put on the back of a truck cheap cheap and it got delivered to my door, was so happy :thumbsup::cheers::banana:
anyways , took the block out of my car to get ready to drop a new motor in , again! :D
couldnt notice how it was sittin at the rear haha
BAWLAA
got a couple of mates over to give me a hand to rip the wreck apart
but this resulted in some suprise buttseckz ;)
finally , ready to come out!!
me doing angry face while jacking engine crane
finally got it out and decided to go buy all the stuff i needed for it !
Motul engine oil
Gearbox Oil (got the wrong stuff so went to my sponser and got hooked up with some ulx110)
OEM Clutch Bolts
OEM Scopot Bush
KTS Strengthened Pivot Ball
OEM Thrust/Throw Out Bearing
also picked up some power steering fluid the other day aswell
got a mate to machine my flywheel and clean my clutch up a bit
this is how we align clutches!
and here it is going in :P
all bolted in now
all i have left to do is bolt up my front pipe , put some oil in the engine and box , hook up the power steering reservoir, put the radiator in , mix up some coolant
then turn the key :P
all comments welcome
https://www.sau.com.au/forums/topic/294477-my-r33-gtst/#findComment-4918363
Talk about drama!
thats some story, glad to see your car's running again though..
the things we'll do for what we love
ill be glad when im on the street once again , for now im psyched its running but still sad that i cant drive it
hello trade plate weekend!
Good work Mitch, youve earned it!
Thanks Dion!
what you doing this weekend?
i should have a trade plate for the car and im keen to get out for some pictures+ cruise with some of the boys!
https://www.sau.com.au/forums/topic/294477-my-r33-gtst/#findComment-4918590
Cool but now u'll have to sell the plates :D
keeping them for a rainy day :P
just gonna run standards for now obviously
////update
got the car running all fine tonight , was wondering why there was smoke coming from the front pipe , then me n my mate realized it was a brand new pipe so the paint is burning in still.
took it for a test run up the street , blew a cooler pipe off under load ,fixed that , checked over it multiple times and its all running fine now :(
so happy !
https://www.sau.com.au/forums/topic/294477-my-r33-gtst/#findComment-4920669
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
