  • Replies 114
Posted Images
yeah it is a shame its not 'natural'
its a tree house thing i guess. there is a bridge over a billabong outside all the villas where we stayed. i thought it was cool so i snapped a few shots. got some sunset pics too that ill eventually go through lol
it was hard to sleep there, dead quiet and pitch black. but a one bed villa with a spa IN the bedroom was awesome. for anyone interested it the 'Broken View Estate' and they make a nice white if youre into them. im not, but it was tasty
Thanks. Yeah it was. We did a day trip down. Very rushed but now we know for next time to take a couple days and get to explore the region a little more. I know we missed out on alot of nice walks etc due to time shortage.
i know that feeling, i hired a car with a mate to go to the 12 apostles from melb. people told us it was only about 2-3 hours away...... 6 hours later we got there just in time for sunset :)
Edited by zei20l
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
