Hey Everyone,
Picked up my new Stagea on Saturday. Big thanks to Ben from Northshore Prestige for answering all my questions!
I plan to keep the outside standard and concentrate on the interior and underbonnet modifications.
Has anyone in Sydney got their TV and DVD all sorted or is it still being worked on?
Anywany here are some pics, any suggestions or comments are welcome.
Hope to catch up with some fellow owners on a Thursday night meet. I'm from Parramatta.
Cheers
Andrew
https://www.sau.com.au/forums/topic/294539-new-stagea-owner/
Hey Everyone,
Cheers
Andrew
Nice purchase Andrew. Welcome aboard!
You couldn't have bought from a better place :(
Your plan is a nice one, in theory, although I would be interested to see how where you are at in a year or so.
Even another Andrew with a M35.
Yes, it is possible to sort out the TV tuner to work locally (I have plus a few others) but the personally previously selling the units on the forum is not doing them any more.
I know Chris Rogers has a solution but I do not know the cost.
Cheers
Andy
