hey guys i'm torn between the castrol edge 5w-30 and the motul turbolight 4100 10w-40 for my next service. would like to know pros and cons for both and past experiences. i've read the oil thread and i know the motul gets heaps of good praise but i want to know about castrol edge more from the people that use it especially with the hotter months closing in.
another question i wanted to know is if castrol vmx 80 will be fine for my gearbox and if not what other alternative around that price range would be better? also what can i put into my diff?
i have a daily r33 gtst series II with 105,000kms. thanks
5w-30 will protect better when cold, but depending on the condition on the motor the hot rating might be too thin, you'll only know you have blowby issues is by going ahead and trying it.
hi there guys, i'm facing the same problem choosing the correct oil for my v35 ,engine model vq25dd, hope one of you may be able to advise me of a suitable oil. I live in botswana and it's a similar climate, very hot, i have a choice of shell 25w-60w,15w-40w, castrol magnatic, havoline semi synthetic? which do you think i should use
No other choices than the above 3 (I'd probably chooce Shell or Havoline, hate lowspec Castrol oil)?
If 25w-60 and 15w40 are the only options, then 15w-40 I would choose, 25w is just too thick when cold.
thanks for your input guys. ended up getting the motul.
been recommended vmx m and not the vmx 80. does anyone know the difference? also would like to know if the nulon 75w-90 semi synth smooth shift gear oil would be suitable. nulon suggests their 75w-85 100% synthetic but would liek to know if the semi synth will do fine?
Castrol Transmax M is used for automatics
Castrol Transmax M
A mineral oil based, general purpose, automatic transmission fluid for use in a wide range of automatic transmission applications
its been proven before and if your gbox is in good nick stick to vmx80 and you will be fine
In a good condition RB25 I HIGHLY recommend Fuchs 10w30, Bursons stock it, Have been running it in the Stagea for 40k km, motor is cleaner, smoother, more economical than when i first got it, i have run motul once, wasnt a fan.
Their 10w40 is another option. Motul 300v I understand, but the lower end stuff I dont get the hype. Chuckie has had his oil regularly tested up to 20k km and the fuchs doesn't deteriorate.
Same, smells nice too.. :(
Had a workshop replace the transfer case for me, they put in decent gearbox oil but it doesn't like it, 4th and 5th synchros are a bitch. Going to dump it and go back to the vmx80 that I was running before without an issue.
Ive never had a problem with castrol edge, and ive been using it for about 1.5yrs now, I use 10w60tho. I believe some drift teams are sponsored by it and havent lost an engine.
I haven't had any probs with Castrol Edge 5w-30 for the 3.5yrs I've had my car. it's the only decent 5w-30 readily available off the shelf that i've found and it's the recommended weight in my manual.
my car is NA though.
it would be interesting to know how many of the above mentioned oils are actually certified as meeting there advertised spec. And viscosity as in the thickness is not the spec either. Should be running a SL spec oil or higher which is commonly a semi-synthetic at the very least. Check on the back of the packaging. If its not got the API stamp, then you dont actually know what you are getting and 80% of oils retailed off the shelf havent as it costs big dollars to have a product certified.
Repsol oils are what i used in my shop for 5 years for this reason.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
