  • Replies 53
Time for a upgrade of the suspension me thinks....after i upgraded mine there is no squatting and more hauling ahead
Your car doesn't squat because you dont have over 300kw and 4WD traction.
We have a winner! GTR's drive totally differently Mr Krishy...
Bec, that's a great result, congrats! Be interested to see what mine pulls on that dyno, may be a touch high reading
with a forged motor and aftermarket turbos why would you bother tuning it at 16 psi?
total waste of time and money.
above 24 psi is where its at.
give it to the bitch and reap the rewards.
if you cant handle the power you shouldnt have built/purchased the car.
pffftt, 2.1 Bar gets the juices flowing
Like I said, I wanted a safe tune. Without all that stuff over 300AWkW isn't necessarily "safe".
I didn't buy the car to do launches. I bought it to do ALL of what GTRs are meant to do - go, stop, and most of all, turn. I wanted an overall magnificently HANDLING car. Much more than that at the wheels on these starts to get twitchy as others have found out.
At the end of the day, it's my "wasted" money, I worked hard for it. I have to drive it, not you, and to me it's no "waste" at all, so really, that's all that matters :P
Edited by missbecjane
Thank you everyone for your positive feedback - I'm still new to a lot of aspects of a car like this! Everyone's been really helpful and supportive, thank you :P
Thinking of heading out and about tonight! :D
uleh says "time 4 yoo 2 show us ur f00ly h3kt1k dr1ft sk1ds yo"
*facepalm*
-D
Mine has 315 AWKW on 20 psi with stock motor, and aftermarket garrets, Goes like the clappers when u wind up the wick above 4500rpm, but no wheel shutter as i re did the suspension and subframe bushes myself. Got a fully built head and 272 jun cams on the way next week, so should see around 400kw when shes done.
But well done Bec, its your car, do what you want to do with it, dont let others tell you you should do this you should do that. Beautiful car i might add.
Edited by Adelaideprosound
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
