just put on DMS 50mm on my 34gtr. its really nice coilover and i can go corner much better. my setting is
damp:F and R soft to hard 2 turn repound: haven't touch it yet.
only one thing make me unhappy. it make some noise, when the road is flat, the noise like birdcall (zi zi zi zi) not loud i can't notice it if I open the window or music on. but if the road is not flat. it make some knock, all the noise come from rear (I have cut the rear trim for easy adjust rear suspension).
anyone can give some idea??? is that normal??
https://www.sau.com.au/forums/topic/295582-dms-50mm-coilover-make-some-noise/
Were they installed with new strut tops front AND rear? Skyline DMS 50mm need to be installed with new pillow ball strut tops front and rear, you can't re-use the existing tops at either end.
The chirping noise may be a dry shaft seal, prone to making the sort of noise you describe.
DMS used to supply a circular metal "top hat ring" to weld to the OEM pressed metal top spring seat, and a turned out DMS top spring seat to slip over the top hat ring. That way the OEM top seat / and damper shaft bushes can be reused. Pillow ball tops are not required given the design nature of the suspension.
i only have new strut top on front:( they didn't told me i need rear one:(
thank you for help
so the strut top is not required for DMS 50mm coilover?
i went to Neal lowe today (DMS dealer QLD). they reckon the valve make some chirping noise. actually the front and rear all make chirping noise, i just coundn't hear the front noise during drive. if i press the 4 corner of my car, i can hear the chirping noise on all 4 corner. so I assume its normal. but what the knock come from? :banana:
Aftermarket strut tops are required front and rear for the DMS when fitted to the Skyline! We deal with DMS on a regular basis (ourselves and Neil Lowe are the only QLD dealers), and straight from the mouth of the engineer that makes them, they need aftermarket strut tops!
Things must have changed from just a few years ago then, when DMS supplied our ER34 Tarmac struts AND the above hardware to mate up to the OEM pressed metal tops.
The assembly was done locally by the DMS agent with instructions faxed by DMS, and is a good solution that does NOT require new tops.
We still have the struts although they are no longer in the car, unfortunately the instructions were sent on a thermal printout fax so somewhat faded but still clearly indicating they came from DMS.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
