i've recently started feeling some shuddering, or jerking i.e "juddering" and the engine feels like its cutting in and out kindof..
started at 100->110kph, then once the car is quite warm it happens at lower speeds aswell!
i was thinking to check all my pipes and the seal (looks a bit old) below where the BOV is (cos it vents to atmos)
any other ideas??
anyone else had this issue beforE? :(
(picccccccc)
Tomas.
https://www.sau.com.au/forums/topic/295790-shuddering-boost-issues/
  • Replies 67
You should probably block that pipe off...
oh so a seal like that doesnt cut it? (it actually looks like a rubber doorstop (possibly IS) )
Edited by atomaly
Try replacing the stock (plumbed back) bov to se if that eliminates the problem. have you replaced your plugs lately? (With say NGK BCPR6ES gapped to 0.8mm).
i have a problem there. i bought it as is! so no going back to the stock!.. it has only started doing it last few times i've driven it..
and when i got the my front breaks done, i was informed the "door stop" seal looked like it needed replacing!
i havent replaced the plugs as of yet since i bought it about 6 months ago!
maybe a good time to? :( i'm planning on doing it myself (i havent done it before)
anything i need to be mindful of? i'm a bit of a n00b haha.
and wheres the best place to get the NGK plugs from?
i found this..
Spark Plug Guide for RB25DET
what kinda load? at WOT?
Ive us a bit more of an explanation on when its doing it mate
when its warm it happens pretty much on medium to heavy boost, but normally starts at around the range of 2500 RPM.
i do remember its always had a bit of dip at that mark, but was never juddery and noticable til now!
when its cold, its not really noticeable (hence when i got my breaks done they couldnt notice it when they went for a drive)
maybe a good time to? :) i'm planning on doing it myself (i havent done it before)
i found this..
Yep that guide is from the "how to " section in the skyline part of this forum. Ther's another guide there as well. While you've got them out carefully examine the coils for evidence of arcing.
Hmmm, maybe a very specific detailed description would garner some more knowledge from people in the the know. I'll put my two cents in though :) The judder you describe sounds very much like the airflow issue that my car experienced when I put my front mount on. Have you added any new mods to the car recently? Too much airflow causes the ECU to cut fuel until the airflow level is at an 'acceptable' level again, it will do this repeatedly as long as the problem is present which causes a 'misfiring', 'jerking' and 'juddering' sensation. I wonder if the seal has perished then it may be altering the air flow characteristics of the system? I would buy what's necessary to plug that hole tight, get the spark plugs and install and test separately, if you do both at the same time then you won't know what the problem was :D
harts.
Edited by stageaharts
Hmmm, maybe a very specific detailed description would garner some more knowledge from people in the the know. I'll put my two cents in though :down: The judder you describe sounds very much like the airflow issue that my car experienced when I put my front mount on. Have you added any new mods to the car recently? Too much airflow causes the ECU to cut fuel until the airflow level is at an 'acceptable' level again, it will do this repeatedly as long as the problem is present which causes a 'misfiring', 'jerking' and 'juddering' sensation. I wonder if the seal has perished then it may be altering the air flow characteristics of the system? I would buy what's necessary to plug that hole tight, get the spark plugs and install and test separately, if you do both at the same time then you won't know what the problem was :)
harts.
thanks! i'll change that rubber seal to start with! maybe replace it with something better? what would be the best way to plug the hole tight? / what to use? (sorry i've never done this before :D:) )
i've only noticed the juddering 'since' i got the car serviced and the oils were changed,
and also the gearbox was serviced (which fixed my 4th gear synch issue)
the juddering only happens after the car is warmed up quite a bit. (say 30 mins of driving) :D
he did mention about the seal being perished when i got the service though!. i had a bit of a fiddle with it last night, and it seems quite stuck-perished onto the pipe! (and i didnt wanna force it off and break it b4 having something to put back on it) haha
Edited by atomaly
gapped to 1.1 runs better :)
i am going to try this "theory" of needing small gap with high boost on the 32 when i up the boost... going to try low-mid 20's psi with 1.1 gap...
stagea stock boost 1.1 is fine, r32 14psi 1.1 or .8gap is fine. if it isnt i would be trying silicon on coilpacks as others have
gapped to 1.1 runs better :P
just spoke with my mech and he said the same thing :P NGK BCPR6ES gapped to 0.8mm!
i'll check the coils for arcing while i've got them out!
From a 'spark' perspective, if your stock setup misfires at 1.1mm then you've either got knackered plugs, or coils or both.
Running a smaller gap makes is just making life easier for the spark, and on 'mild' engine is simply masking another issue.
(Your economy and power will also suffer when you start closing things up)
in regards to the BOV return pipe seal being perished... what would be the best thing to use to seal it off this time, and where would i get it from ?
i'm a n00b i know! :D
Edited by atomaly
i'm a n00b i know! :)
anyone? :) i had a look in a few different auto stores but they have nothing even similar to what i need :)
pull the steel pipe off and get a cap welded on. thats if you can afford to have the car off the road while you do it. or get a piece of silicone joiner or similar, put it on the return pipe and use a steel bung to block off the other end of the joiner. this way you can easily put a plumb back bov back on if you want to.
i think you'll struggle to find another bit like whats already on there, i know you get one in a HKS SSQV kit, maybe other manufacturers supply something similar, post up in the Wanted to Buy section and see if anyone has one lying around they aren't using.
You could go to a wrecker and get the original hose or go to an engineering supply store and get a short length of hose the right diameter and then either get a steel plug from the same store or if they don't have one from a plumbers supply store or just cut off a piece of solid steel pipe (maybe from an engineering shop) and stick that in the hose and secure it with a clamp.
okay so i posted in the general Forced Induction Section of SAU.
aparantly its most likely my 02 sensor playing up :D ( should be changed every 80,000km according to my sources ) . will go for a drive tonight with it unplugged and see how it goes :)
Changed? Bugger that.
Drop around mate and I will try cleaning the AFM for you. If not it could be the solder joints inside. Then start changing things.
Edited by scotty nm35
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
