Still ugly
and on the subject of ugly, who thinks the new liberty is horrible..
The last one was gorgeous, and the wagon looked even better..but somewhere they've got it all wrong with the new model
i tried to find a pic but for some reason it looks ok in pics, but on the road its an eyesore
Still ugly
I agree.
However i believe the technology/drive of the new one is far advanced to the prev model.
I'm currently driving one (i work for Inchcape which looks after a number of Subaru dealers) - and i will admit at first i didn't like it at all.
But after driving a few times i've come to appreciate the differences.
The only thing i'm still not real keen on is the electronic handbrake. Because i've seen these fail (not in Subaru obviously) time and time again, i'm just counting down the days before we can't get it to release/activate
I have been wondering why for the past 2 nights I have suddenly being waking up and tasting vomit in the back of my mouth. I must have been dreaming of this shit box S60, heres me thinking it was the new STAG. :P
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
