  • Replies 135
Woooooooooooo Hooooooooooo 8.9 @159mph the car was great today i need to work on the 60 foot but it feels strong. compak attak here we come!!!!!!!
A big thanx to CV perf, BMS transmisions and R.I.P.S NZ
full trim drag radials and heavy as a mother f**ker
Makes 650kw at all 4 and yes the 3037s are still there
What is your target, is a low 8 within reach :)
Were u running 30psi with c16?
Have any other clips of the car or even the 8sec run?
What is your target, is a low 8 within reach :thumbsup:
I think a 8.70s are possibe. The turbos are running out of puff but look i only ever wanted to run a high 9 in this car so im stoked
I do have videos but im to dumb to know how to up load them. let me see what i can do
Auto was built by BMS performance and it will cop whatever we throw at it.
Edited by superjet760
A big thanx to Shane 1jz747 for organising today. I appreciate it mate
x2...it allowed us to find quite a bit lacking in our set-up. Thanks Shane...Should be sorted for Compak.
Awesome time, awesome car and most importantly awesome fella.
Well done mate.
OMG, if u work on that 60' time it will get closer to a mid 8
i think paul pulled a 1.49 60' (or was it his wife stacey hehe)
1.35 Marko...only a 1.54 today. Stace has done a 1.69 on Federals though...pretty stout!
Edited by Swiper the Fox
Well done mate.
Thanx Paul
We were happy with the out come. I think its got a bit more in it so we will see what happens at compak attak
Wiping drool off face... So nice. Love the sound as it lauches and looks tough as. Hope one day to have a 9sec street gtr!!!! Working on it slowly as we all are ha ha. Is the headlight duct legal? I wasn't sure but seen it on a fair few high horse power gtrs now that are on the street.
Good luck with the car mate. Very impressive.
i think with some suspensions tuning the black gtr has planty left in it, i didnt get to see the 8 sec passes i think i saw 2 9 sec passes and it was a hand full using up a fair bit of the lane. i reckon that auto was a great move, the car is beautiful to look at, i and many other were very impressed with it.
no dramas on organising the day, there will be a few who attended who will not be welcome in the future as they could not adhere to simple track rules of wrist bands and crew sizes.
other then a few trouble makers i think every one had a pretty good day, althought the cressida didnt make it i had a great day helping out our guys and watchin everyone else have a good go.
Shane
Does anyone know what the fastest radial tyred gtr in the world is?
I know croydon wholesale 32 is the fastest street tyred but he uses et streets and they are not radials.
It maybe Mark godzilla motorsports
Can anyone confirm
Thanx
Paul
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
