Cant Work Out Why My Car Has A Low Idle And Stalling On Hot Starts
cold days it is fine, but if i drive somewhere say to the shops, it reaches operating temperature then come back 5 minutes later it acts up, or just on hot days.
ill start it, it will idle low when i accelerate it will sound like its running on 3 cylinders and pisses out black smoke, if its doing this in stop go traffic it will run like shit stall & piss out black smoke
i know the black smoke means un burnt fuel
anyways the cars history
r31 skyline, rb30e,
2 years ago reconditioned the head at my work shop, had cam reground, raised to compression from 9:1 to 9.6:1, stock computer
year ago converted it to manual,
since the manual conversion its had issues, replaced start motor, alternator, all new belts, 2 afm (1 new), new bosch coil, new thermostat, radiator cap, radiator hoses, 2 dizzies (1 was out of a vl and was told the wiring is slightly different to the nissan)
every 3 months/5000kms i change oil and filter, every 6 months 10,000kms i change oil, oil filter, spark plug leads and spark plugs, every year 20,000kms new fuel filter, air filter etc
i have changed just about every sensor, bought all genuine, sprayed 2 cans of carby/ throttle body cleaner, AAC is clean and carbon free, had injectors cleaned
i replaced the reground cam with a standard cam
ive had numerous mechanics look at it and its either not been an issue when they had it, or they couldnt find anything
im starting to think maybe a cylinder or to has excesive clearance or the rings are on their way out, but it doesnt use any oil
any1 got ideas?
Not familiar at all with RB30s so this might not be any help at all to you, dodgy ignitor modules malfunction when they get hot, though usually it results in misfiring, might be worth also finding a better ground for the ignitors ground wire.
For the RB20 (yes, I know you have a 30E, but I don't have the manual for a 30E), difficult hot starts can be caused by faulty temp sensor, or fuel pressure.
Since you've replaced the engine temp sensor, maybe try removing the vacuum line from the FPR to get more fuel pressure.
And if the engine can't spin fast enough, due to faulty / dying battery.
  • 4 weeks later...
I'm pretty sure they have an ignitor module - little black box on the side of the dizzy body.
solved,
my thermo fan that came with the car didnt work so i wired up my own thermo fan, found out the sensor that tells the computer that the thermo fan needs to come on was confusing the computer, ust so i just disconnected that switch
thanks everyone for their help and suggestions
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
