the 180s you are talking about, have 4 stud, small brakes and red top SRs. inferior compared to a s1 s14.
however, still sold on r32s.
But the R32 has an RB20DET, which is inferior to everything.
If I remember correctly, only CA powered S13s come in 4 stud. S13s that left the factory with SR20DETs are 5 stud. The brakes are small, but almost all street cars of that age are underbraked for the power they can make with mods.
all 180s came with 4 stud, a friend in a '97 typeX just did a 5stud conversion. small brakes compared to the 4 pot r32 brakes.
rb20s lack the torque true however, i have heard too many stories of people destroying SRs. also, SR motors are overpriced, at least 2k for a replacement, never.
Edited by Peter89
yeah all s13 vehicles (that includes ALL 180's even the late ones with the black top motor as they are still a s13 and the engine is still a redtop which has had the rocker cover changed to black) are 4 stud.
as for being under braked, i thought that the bigger brakes weren't standard on all turbo 32's and were only on the type m 32's, unlike the 33's which all turbo models had them. i could be wrong though. never really took much interest in the finer details of the 32 models.
also i would have to say that the sr20 is a superior engine to the rb20. sure they have rocker issues when held on the limiter for a while, but other than that i would say they are more reliable than a rb20. less issues with turbo failure thanks to steel wheels, and with the rb20 turbo failure can also come engine failure if parts of the turbo make it into the engine.
double checked, only type-M R32s came 4 pot brakes. so you're right.
while, rb20 turbos aren't strong, that's an easy fix. probably bolt on a rb25 turbo when i have the cash anyways. however, spending 10months on nissansilvia, i did learn that SR bottoms ends aren't that strong. also, even if rb20s are more likely to fail, they are half the price if not more. considering the car is on a tight budget, seems like a better idea. considering, if i get a s1 s14, i would have to get a s1 s14 or later engine, probably around $3k for the engine alone. rb20s go for around $1k, obviously older and less popular but that's a decent price difference.
really doesn't matter that much, it's my first car. ill probably ruined it anyways :P yet ill have to experience required to look after/drive a TT supra or GTR afterwards.
It may be inferior in performance but mine has hung on with 24psi pushing 230kw and limiter all day. If it's a reliable engine you want then 32 is best.
If I was buying a car now I would be looking at the silvia platform. Probably an S14. Performance parts are easier to get and cheaper. Also they are probably a better chassis for hill climbs, motokhana's and drift. Of course they do well at the track too.
So you can have an aus S14 but not a SR S13 with the old rules?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
