  • Replies 134
Well it looks like the cam belt came off, engine overheated then went POP! really i'm lucky i pulled over when i did i could of melted a rod or piston or at least something.
If i went a Rb25det what would i need to change?
Look in the NA section, there's heaps of info there.
But to be honest, I don't reckon rebuilding an NA engine is worth it.
No i don't think so either and i was going to end up dropping RB25DET in the 33
Yeah, you could always sell the other working parts from the DE engine or even some of the running gears that you might replace with the turbo parts, eg brakes, exhaust etc.
enigne, brakes, computer for engineers
and probably just change the whole rear k frame if you can afford it then you got brakes on rear and a better diff - not sure if you need to change the rears for engineers cert though.
best thing buy a halfcut and strip the shit out of it
Just got off the phone with the mechanic $2.2k for a N/A and has done about 62k
Surely that's way over price.
From what he has told me i have no compression in 5 cylinders and the valves are rooted, coils need to be replaced
could prob find an RB25det package on here for that...
Jesus Christ this turned into one expensive bloody weekend
thats only if you go rb25det
cause the computer is diff to NA one, will need the turbo brakes...at least at the front and then you have your engine
it could be done cheap if you sourched parts here and there, but a lot of farking around
then you will most likely need a diff to cause the na one wont haddle the power, which is why i suggested the k frame just unbolt the old one bolt up the new one and you will have 5 stud hubs to
For no compression in you car will be the valves, broken or whatever they always come up as 0 compression
doesnt mean that the bottom half of the engine is damaged, could just be the head needs new valves/machining etc
but you wont know until it gets pulled apart
Forgot what the town was called, but we stopped to fill up on snacks
The town is called Mansfield *sigh* Sadly, I live in it. I wish I knew you guys were in town, I would have pretended my VRX was a skyline and snuck into the cruise :P
@ Ashneel, if you come up on the next cruise, you can check out your old TH hahaha :happy: . Still running! Although, it's changed owners now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
