much hate bort!!!
i just remember it running a fairly low mph last time it went down to the plex, figured something must have been fixed to get power back up there
Marbles only change made from when it ran at WAW was from the bridgestone r comps to R888 toyos and power still the same :)
  • Replies 40
It's simply impossible to run 10 second pass form a R32 GT-R in stock form Char, even with some boost ramped through the turbos. Unfortunately there is dreamers around the place who make those sort of claims and can through our peoples perceptions on what stock car's can do.
Top work with the pass, be keen for further 60ft and mph details.
Bart, Say congrats to Will, I'm more impressed with the 55sec at Wanners though, and I know that was only the first few test laps, so sure it has more in it :P
Yea PC the 55 was good considering it had miss n yet to get on the brake hard .. We be there for the next No Limits in december to try again :happy:
cool story bro? wasnt it u who asked if it was mph. also, dont call me an idiot.
all i know is he claimed to know sam ie slyder and he owns a silver r32 gtr..
i know the guy. its a white 32 gtr and it ran 11.2 or somthing with 1.5bar boost (he thought it said 15psi).
back on topic, i like the rims :P
Yes, I asked what mph it ran because that give you more of a indication about the cars true power and I was interested...
You on the other hand wouldn't think of that because you have no idea, go back to school :P
nice one, and nothing wrong with white rims.
when i was at kwinana last, a bloke ran high 10 with his stock 32 gtr with just boost controller, God knows how much boost he was running though he kept winding it up more and more. i wonder if his engine made the trip home
only chance of that happening is if he bought a !@#$%^&* GTR and he doesnt know what the previous owner(s) put into it
otherwise 2 your both on crack :P
no need to be a f**kstick ^
from what I have read with intended boost the GTR was ment to run from factory is around 12.90 down the quarter
"The electronic boost control had a small physical restriction in the control lines. It was marked in yellow so the new owner could remove it and enjoy a safe factory boost increase.[15] After this increase the car would put out ~230 kW and could do 0-100 km/h in 4.7seconds and quarter mile in 12.8 seconds. "Wikepedia" "
Edited by BANGN
With NOS?
Highly unlikely, most street nitrous kits will see you gain about 30-70rwhp so possibly high 300's hp. Anything beyond that sort of boost and gas will see stock parts breaking and flying heads flying into the sky. I drove a bog stock GT-R with pods and a exhaust to 12.97@107mph, pretty spot on and considering the age they work well. To run a 10 in a GT-R you need around 128+ mph and beyond 550rwhp, working off figures in WA in the past with a good starting 60ft.
Edited by monga
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
