hey guys
i've got an rs4s (series 2) and i've only got one key which has the remote built in for the central locking
i wanna get another central locking key, is this possible? or will nissan charge me a stupid amount for a new one?
Thank
Tom
https://www.sau.com.au/forums/topic/296726-only-one-key/
Get an immobiliser alarm system with 2 key FOBS.
Option it up with glass break, shock sensors and ultra sonics.
Dont let your stag go walking or be posting up here when it gets stolen and have to answer the question if it had an alarm and immobiliser with a no.
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-4942791
thanks guys that is what i was thinking
it would be nice to keep the standard door remote but i need to get an immobiliser fitted anyway (justcar terms for cover in the event of theft)
any ideas of what i should be looking at? i know viper are good but aren't an aus standards black wire alarm
can anyone recommend somewhere that does good installs in the gold coast area?
Cheers
Tom
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-4942855
Cheers
Tom
i got a mongoose m80g ! it has to meet the australian standard to comply with just cars i think (im with them too)
came with a turbo timer too :thumbsup:
once the novelty of the blip blip wears off you'll prob want to set it to silent lock and unlock, which can be done too!
Tomas
Edited by atomaly
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-4943093
ive got a mongoose versinity sensor imobiliser, it just unarms when i put my keys in the ignition as the fob is hanging right in front of the receiver. ive kept my standard key working.
more info on that please
but will have to find something to do lock/unlock
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-4963174
Cheers
Tom
run the car up here and I'll do it.
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-4965537
  • 3 months later...
I got a viper alarm and these bad boys off ebay, Standard keys are teh suxors.
Put "nismo Key" in as your search string
Hi Mate, I am pretty new at this, but just wanted to confirm that the 2 "nismo" keys you got off ebay worked okay with your r34 before i buy a set ?
Thanks
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-5160046
Thanks
https://www.sau.com.au/forums/topic/296726-only-one-key/#findComment-5160048
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
