Hi guys I wonder if anyone could help me,
We have fitted the engine,box and loom(inc pfc)from an R33 to my 98 R34 gtt
Its all gone well and the car is starting driving ok,where im having the problems
is with the speedo,rev clock,and water temp,Iv been told that simply connecting the relevent wires to the R33 ECU wont work....any ideas?,help/advice would be great.......
I also need help with the abs system should it connect up fairly easily to the R33 ECU?needless to say wiring is not my strong point........
sorry to drone on,one last thing,If I was to get the loom from an R34 Gtr would it be a simple plug and play affair
to get everything working?I know I would need a new ECU......
Thanks in advance.
my apologies to all, the tacho is not working at all,nor the speedo,im not sure where the r34 will get its signal from
the r33 pfc and if the r34 speedo will accept a signal. From the r33 box,once again all help and advice greatly appreciated. . .. . Thanks.
this is off the top off my head so i will check it later,
yellow red trace is tacho signal,water temp is yellow / black, speedo is yellow / blue all these wires are in the other white plug (with black cover and grey locking lever) near ecu plug,
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
