Hi guys (and gals),
I'm doing the manual conversion to my Stagea and therefore have a series 2 Stagea tiptronic box for sale ... for the same price as installing a shift kit at MV Automatics!!! $475
The box is 62,000kms old
First service on box at 28,000kms when I imported it
Has stage 2 shift kit as fitted by MV Automatics at around 45,000kms
New solenoids fitted by MV Automatics at around 60,000kms
Also serviced at the time too when solenoids were fitted.
$475 ... no offers! You're getting alot of extras with this box as is.
PM me with interests
Located Adelaide SA
https://www.sau.com.au/forums/topic/296909-fs-tiptronic-box-with-the-works/
got a quick question, is the gearbox exact same as the one in a r34?
I'm told it is by MV Auto. But the gearbox is for AWD, so it has the transfer case naturally.
ant idea whats involved to run in a series 1?my trans is dying
Not sure. Can anyone else answer this. I would think the loom would be different for a start being tiptronic?
Hey bud, will you be avail this friday night for your refund? Got your sms but been busy, yet again.
Ruby
Bargain, solenoids are more than that alone. Nearly $1,000 worth of improvements there. Almost tempted to get this as a spare!
Then do it :D
If I can sell this box within the week ... I can pay someone else to install the manual and make it their problem ;)
Or throw the cash at some extras :bunny:
Then do it :laugh:
If I can sell this box within the week ... I can pay someone else to install the manual and make it their problem :laugh:
Or throw the cash at some extras :)
Did you have any idea of how much it would cost to get the box to Perth?
I would be interested if I can get it over.
  • 3 weeks later...
I have absolutely no idea. You will have to enquire. Weighs about 90kg.
Tiptronic gearbox is now out of the Stagea ... doing my manual conversion now.
Get yourself a bargain ... if not sold by the end of the year, it'll just get lost in my garage.
You'd think that would be the responsibility of the buyer, but I would suggest you would be looking at some extra wiring, a series 2 ecu and associated grief to run it properly amongst other things...
I'll take it if you fit it.
hahaha.
If you can check out how much will it cost to put it in series 1 and what parts involved? I will be much more interested
Correct. I'm selling a worked tiptronic box. I have no idea what is involved with fitting it to a series 1.
Would delivary to queensland/brisbane be an issue?...or just at a amazing costt
It would only be an issue for you as it will be your responsibility. I'm happy to help out where I can (ie be available for the pickup).
Box still for sale.
PM me with interests please ... I don't frequent the Stagea FS section much sorry.
:P
  • 3 weeks later...
pretty keen ruby
also in adelaide
i can have money to ya by the 8th of jan ..
pm me :(
Never heard back from you.
Nobody wants this box? Going in the shed after this weekend to be lost forever.
Had 3 people now not come thru on the deal. :banana: 1 more interested party, then its going into the shed, no longer for sale after that.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
