R33 Skyline Number 9 On Top 10 Greatest Ever Sports Cars
i am just excited to see a skyline on Discovery Channel lol
was watchin this show called greatest ever and they were showing the top 10 greatest ever sports cars and i was surprised they showed the r33.
it will repeat at 1130pm tonight on discovery. if ur bored watch it.
Peace.
  • Replies 109
That is because R33's ROCK and blow the doors off other cars.
There's a lot of jealously from other Skyline owners because of that. :P
Most jealous of all are A31 owners. :)
LOL I'd rather choke eating the vomit freshly squeezed from my stomach than drive one.
If you want to see a good-looking 33, look no further:
http://i10.photobucket.com/albums/a130/VIP...6-14-09/126.jpg
edit: i lie, heres another good-looking 33:
http://www.lightningmotorsport.co.nz/image...7Dmax%20c33.JPG
Edited by Dorigecko
Which car was banned from Australian Touring Car because it kept kicking the SHIT out of EVERYTHING on the field? That's right, the R32 GTR. Never saw an R33 win as many races as the R32's :P The herritage came from the 32's. I could throw a rock down the street and accidentally hit a 33 I didn't even know was there they are that common. Not to detract from the 33's themselves, they are still nice cars :action-smiley-069:
*simon likes this!
The ONLY reason a R33 Gts-t is any good is the strong gearbox and some may argue the RB25, although the RB20's are better bang for buck and bang for capacity!!!
The rest of the car is worse than a R32...
R33 GTR have a better ATTESSA system than a R32 GTR, but a V-Spec R32 is pretty much the same or better in every other way :action-smiley-069:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
