hi guys im having a poblem with my S2 attessa 4wd system ,
i have just fitted 2 second hand tyres one on the front pass and
the other on the drivers rear . both tyres have 50% tread and
all 4 tyres are the same size 245/35/19 . now when i drive the car
the 4wd system is coming on under normal driving conditions
front torque gauge reads anywere between 5 kg/m - 10 kg/m
and the car feels as if it is surging . im thinking that maybe because
the tyres are actualy slightly a diffrent rolling dia so therefore the
attessa system sensors are telling it that one of the wheels are spinning
enough to engage the 4wd . im just wondering if anyone has come across
this problem before ??????, there was nothing wrong at all with the car
before the 2 tyres were fitted , and no one touched the car at all while the
tyres were fitted and the guys who fitted didnt break or damage anything
because i watched him like a hawk like i do with anyone who works on my stag
HAHAHA :D;):wacko::D any help will be very much apprciated thanks guys and girls ....
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/
Dude the diff rolling diameter is defs the prob. As a side not I noticed that the 4wd was kicking in more ofter with just lower tyre pressure (I know of others that this has happened to).
Also as kidafa said dont mix n match tyres from side to side on each axle. Not just for safety reasons but u can damage diffs etc by putting diff size tyres on the one axle.
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4950184
And risk damage to the 4wd system? Good advice!
plesae tell me how it is going to damage it ? the rear wheels wont be turning faster than the front so it wont send any drive to the front . and the overall difference wont be any greater than the difference between wheel speeds when driving around a corner. i put the space saver on the rear of mine and it was a flamin mongrel . sent like ten% to the front . unplugged the green wire and it was happy as
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4951837
thanks guys fo your help in conferming what i thought was the problem. i have changed the tyre that was the problem and it has fixed it . but i have booked the car in for 4 new tyres next week so my problem is now ALL GOOD thanks again eveyone who helped out !!!!
https://www.sau.com.au/forums/topic/297204-s2-4wd-problem/#findComment-4956136
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
