Guys,
Recently my windscreen's crack is starting to show and I suppose it's high time to change it before the screen explode in my face while driving on the freeway.
I'm currently with Shannon's and I get 1x free windscreen replacement and they recommended O'Brian for my screen repairs since they come out to houses. Anyone used their service before? The windscreen would be for a r34. Besides O Brian are they any other providers who do wind screen repairs? Shannon's said any repairer will do since the repairer will bill Shannon's directly so I'm guessing here $ isn't a big issue?
One more thing, my window motor pads at the driver side is starting to wear out and as a result I now have a visible mark running from the bottom of the window to the top and also the annoying scraping sound (tok tok tok tok) when I wind the window up or down. Do you know who can replace these pads and also the scratched window? I've been told by a mate it's a bitch to replace windows in r33 as you need to position the glass via 3 directions but I'm clueless on the r34.
Thks in advance all.
Edited by hotchoc
https://www.sau.com.au/forums/topic/297542-windscreen-crack/
O'Briens will do, doesn't matter if you're not paying, does it?
Driver's side window:
What do you mean by the pad wearing out?
Its likely only the tint that's scratched, not the glass itself, so check that on removal, and putting a new window in is easy, you need to attach it to the tabs (2 screws), and align it inside the water seals on both sides...its not hard though, just loosen the rails, move them apart, put the window it, close them and tighten it back up.
Pardon the amateur paint drawing. It looks something like this: -
Definitely sure it's from the outside and not on the tint. I'm thinking the pad is eating away after constant usage hence the bare metal of the motor is scraping on the window. Think it as your brake pads which are worn out and you will start noticcing scrapings on your brake disc. Mind you the car's close to 9 years old btw.
Teo, any window place would be good really. As long as they have the window you need. Let me know how you go, because I need mine replaced very soon as well!
As for the scratches, sorry Nic but Teo is right. It is the pads wearing out, so the window will need replacing. Again, I have the same thing... I've never done a window in a Skyline, but I've fitted one to a Mitsubishi Express van and I hated it... I was a 1st year apprentice at the time and took 30mins to work out how the f**k it went back together. Might be a little easier now.
one thing about getting your window replaced is they will generally use their own manufaturer so you will sometimes get the blue tint across the top of the window, if you dont want this then double check with them that it will not have it as it may need to be ordered from nissan direct..
i had them do a window for me in the front yard while i was at work come home and had a fight with them to fix it as i asked for a factory direct replacement and they said it was... i guess our ideas of factory direct were different :D
teo I work for shannons and Im pretty sure I spoke to you yesterday about your windscreen :)
lol small world after all. can you pls pm me your name so i can speak to you again in regards to the windscreen? Icalled again today just to reconfirm after speaking to o'brian about my windscreen. Apparently, o'brien only has their ADR approved windscreen which i'm guessing here it's made in China. Then i told them i wanted an OEM Nissan one and they said they will ring Nissan tmr but i needed to speak to Shannons to see if i'm covered for OEM replacement.
10 minutes on the phone with Shannons and after a hold for 5 minutes (i'm guessing the guy needed to speak to his TL to reconfirm ) they said Nissan OEM windscreen is covered by them BUT if O'brian needs to freight them, they will not be laible for the air frieght costs. However, if they said i don't mind the wait they can do it via sea freight which is covered. So yeah, everything looks alright from here.
Just a question though, who else stock Nissan OEM windscreens for r34. O Brian quoted me $490 for the 'adr' approved windscreen.
One more thing guys, if i were to go for the adr approved windscreen which is quite unlikely, i've been told that most of them don't come with built in antennas.
So.......... i'm guessing no radio then if i go for the adr approved ones?
Quote from dan666:
my one is the front windscreen so no antenna. Was 100% Australian made (not that it means much haha)
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
