I know this is probably a long shot but does anyone know of any vids showing a GTR and a Hayabusi dragging. Just want to settle a bit of a dispute with a mate and would love to see it anyway.
If not a Hayabusa, then maybe other quick bikes R1 etc and of course with a win to the GTR.
Thanks!
https://www.sau.com.au/forums/topic/29759-gtr-vs-suzuki-hayabusi/
  • Replies 46
Thanks!
I have a video of a modified Supra dragging a stock Hayabusa. Would that help your dispute?
And a win to the GTR would prove what exactly? That you can tailor-build your own car for $80k+ that will beat a $15k motorcycle?
No, actually it would prove that a street registered car is capable of beating a $35000 bike or one of the quickest bikes around which is what he does not believe.
You could tailor build your own car for $80000 or you could just buy an R32 for $41000 with 850hp which is what I am test driving on Tuesday.
Of course a street registered car is capable of beating a Hayabusa.
It all depends on how much money you have to sink into the car. Oh, and just because it's street registered, doesn't mean it's street LEGAL, which it won't be.
Anyway, this is comparing a HEAVILY, HEAVILY modified car vs. Stock Hayabusa.
How about a modified street car vs. modified Hayabusa? Bye Bye Mr. Street Car :D
Saw a turbo-charged blue Hayabusa run at the creek once.  Man that thing flew...  Would hate to think what it would take in dollars on a street car to beat it.
Adrian
I would even venture to say it would be near impossible for a street car to beat it.
Stock busa does low-mid 10s... What would a worked (turbocharged, etc) busa run? mid-high 8s? low 9s?
How many 8 seconds cars do you know? Now ask yourself how many of them are true "street cars"? :)
But the thing is, with bikes that quick and powerful, there aren't that many riders out there that can launch them at their full potential, as they're scared of flipping the thing, or flying off the back.... and rightly so! I'd wet myself piloting a busa down the 1/4 mile, let alone a turbocharged one!!!! :D:)
Hayabusa at Final Battle was converted to 3-wheel, was turbo charged, and had NOS. Talked to the owner, and he said it's run a 5.5 1/4 mile assisted by NOS, and a 7.5 without NOS. And for some reason, it's registered as a car, because of the 3 wheels, and so he doesn't need to wear a helmet....insane
Martin Donnon once pondered in an Aussie mag (prob Hot4's) what it would be like to take the 1300cc motor from a Hayabusa and fit it to a Cappuccino.
Would LOVE a crack at one of those on a track! (Round a track not just straight along it though :D )
Adrian
I don't know what you've been smoking, but a Hayabusa does not cost anywhere near $35k. Unless you're talking about adding $20k worth of mods of course. But if you're talking about mods, see other people's posts above.
well my mate told me they were $33000 + on roads but anyway I got some vids....thanks guys.
Brand new they are just under $20k. Second hand you can get them for under $13k. $15k is about average. Have a look on Tradingpost if you don't believe me. For $35k a Hayabusa would be running 8's easily. I think there's a turbo kit for around $10k, plus you lengthen the swingarm to help stop it looping.
I'm not saying that one is better than the other, all I'm saying is by having a GTR that can beat a Hayabusa is only proving that you have more money to burn.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
