selling standard rb20det and gearbox, 115,000kms, out of 32 gtst
was pulling 220rwkw with highflow 25 turbo and supporting mods
very healthy motor
completely standard now
does not come with a turbo or air flow meter
loom can be included if needed
located in melb
chasing 2k
pm me
https://www.sau.com.au/forums/topic/297739-rb20det-and-gearbox/
  • 1 month later...
Hey mate,
How much for the engine since you parted out the gearbox??
What did you do to the engine to run 220 KW?
Just confirming , your selling everything minus AFM and turbo??
Cheers,
pana
$650, no turbo or afm, i was running a highflow 25 turbo, gtr injectors, exhaust, cooler, splitfire coilpacks, 17psi made 220 with ease
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
