Hi all,
I recently upgraded my brake pads to Endless ones and started noticing quite loud squeaking noises from my front disc brakes. It's really irritating and somewhat disturbing...I mean, I paid extra cash for performance and safety not this sound.
I've spoken to a lot of people with performance vehicles and their brakes also do this sometimes. I have a few people run up to me and say, you've spent so much money on this car no doubt with the exterior and performance upgrades etc, time to give your brakes some attention - and I was like "yeah, I know and I did do that...."
So fellas, how the heck do I stop this - is there a way and if not, is this normal? I came across an interesting article online and thought I'll post it here...how much of this is true...please explain...
http://www.trustmymechanic.com/htmlmessage9.html
Thanks all...
Kevin
Did you use the shims that came with the pads (if they came with them), or used your existing shims and used copper grease on the shims? Lack of shims can explain the noise
I dont run shims, I don't get squeaks, I run decent compounds.
I assume your rotors arent warped and you skimmed them before you put new pads on?
Do the obvious and cheap first ie, lightly sand the pad surface and bed it again, otherwise you might glaze the pad(forms silicon like stuff and hardens up).
Try bending your existing shims a little and see if that helps.
If no go, then try putting some of that red brake glue that you spray BEHIND the brake pads. Anti-squeal shims. This fixed my issue - Adhesive brake pad stickers($4 for pack of 8 from BNT).
If all that fails, it might pay to check to see whether the pots(name) are actually pushing onto the pad evenly. If one of them isnt pushing out fully, then that may explain your squeal.
haha sounds like a bit of sooking here
happens with decent pads sometimes... might be shims might not be
if you care more about the sound than having good brakes go back to your normal street spec pads
  • 1 month later...
I have same problem I have Dba slotted rotors with Ferodo Ds2500 pads work excellent and have been for a year. Then all of a sudden now my fronts are starting to squeel there arse of so embarassing really I've spent a fortune on my gtr and this shits me to tears, pads still have lots of meat rotors have no lip as car never tracked just driven hard like a gtr should be. So to any in the know maybe my discs might need a very very light machine as it looks like they have smoothened out a little could this be the case the pads over time being a course compound do this.
Any thoughts?.
Cheers,
Dave
if you want a quiet car get a luxobarge, you have a gtr... its gonna make noise.
there is a reson you can have a skyline that performs as well or better than a half million dollar lambo for 50k :P
i'm guesing you didn't bed the pads, as you never mentioned it in your post, so take them off, rebed them, put copper grease in the shims and put them back on...
beyond this, just deal with it
yea i got the same problem atm. i have 32 gtr brakes with bendix ultimate pads and its the front that makes the noise. however when i inspected it the pot had been worn unevenly on the pad and so the rubber sticker bit was showing the copper/metal bit on the pad.
i used the anti squeal lubricant but that only worked for 10 min. im not sure what to do eather????????
cheers Evan
Thanks Hamish yeah its cool having a car that performs better than half million dollar Lambo but my brakes never squeeled for a year! of hard driving, but i will take your advice into consideration as i have nothing to lose and all to gain that might work.
And yeah i did bed them in good.
cheers,
Dave.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
