Ive got a r32.4 project up for sale, put some offers up..!
its a 93 r32gtst
its got a wide body r32.4 conversion
sikk back lights, custom fiberglassed
Gtr rear seats
Front slotted disks
custom rear parcel shelf
Bee-R kit
Sunroof
need a bit more work on kit. but most is on
it has a standard rb20det auto in it, running, just turbo has been pulled out, i still got standard one
ive got
Rb20det wich came out of a drag car, it has
RB20 Turbo engine,
standard internals,
adjustable cam gears,
550cc injectors,
Walbro Fuel Pump,
Stinger 4 computer,
Top Mount Stainless Turbo Manifold,
T04Z spec turbo, High Flowed
FMIC,
TurboSmart
Wastegate,
screamer pipe
BOV,
DualStage Boost Controller. 14p low boost, 19p high boost, currently
Dyno. 310bhp on 19pounds.
R32 Turbo 5speed gearbox,
CarbonTechnic Ultra Race Clutch, ($900clutch kit - trade price)
Tomei Quickshifter,
Hi-Flow Cat,
Free Flow Exhaust(Nice Note).
time card for 12.4 sec 1/4 mile before clutch was put in
guages,
intercooler,
pod filter,
BKR8E spark plugs
Reconditioned Rb20det.
this waz in a r31 drag car, ive got pics of car at drags.
any questions?
anY offers?
https://www.sau.com.au/forums/topic/298010-r324-widebody-project/
how much u looking for ?
no idea mann, i really dont want to sell it, ive spent so much money on parts and so much time on it, but i need money for new house, giv an offer, and i will think...
ill offer 4k sence there is alot of work to be done and it has a stock engine in it and auto
its got a stock engine atm, but ive got a 310bp enine to go with it.. i want a bit more dan dat, just the car alone cost me a bit over 4g
what would you want for it if i took the car only, you can keep the engine, both if you want, and i dont need the rear seats as i already have some,
so car only, how much do you want ?
you can take the car for 5g without the 300+bhp engine.
how much for the modded engine?
ill give all the parts for the moded engine for 3g, or 3.5g with the actual engine. i have it up on parts forums, chek it out
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
