  • Replies 216
ok, thats 5.
Only 5 more needed. I'll give them a call and say we've got 5, can they still do them cheap.
Cam, is your warehouse available this weekend by any chance?
ok
thats 7
i'll call car quest and see if they can do 7 @ $135
cam, how much notice do you need for your garage?
if we can confirm tomorrow, can we do it this weekend?
ok, i didn't get the chance to call today, but I will call first thing tomorrow and we'll get it sorted.
one down side is, is that its going to be 39 on Saturday, cooler apparently (mid 20's) on Sunday.
What day is good to use the garage Cam?
i know it depends on the everyone but im out for sunday....saturday this weekend is my day... maybe we can buy them together then have a couple of group installs? just a suggestion.... like uneekwahn said....39 is fkin hot! :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
