Hey fellas, I've been getting heaps of different advice on what I need to do to get my turbo kit on my X-Trail, legal...
I've been to the DPI, they said go to the pits and then the pits told me to go to DPI etc...
Some people (the police themselves) said I just need to take it over the pits and that's it, wheras others (DPI) said I need to fill in this modification form then get an engineers certification... Then there's MOD plates, engineers certificates, emissions tests... (where the hell do they come into the equation?)
From the people who have done it all before (getting mods legal), tell me, what EXACTLY do I need to do!?
Roughly how much am I up for also ($$$)?
Thanks!
https://www.sau.com.au/forums/topic/298331-getting-turbo-kit-legal/
Thanks!
Quick answer,
if its anything like NSW you'll need to get an emissions test and an engineers cert to show that your car doesnt break the emissions laws and that the mods dont lessen the structual integity of the vehicle.
After that you might just be able to drive around with no worries and the certificate will get you out of any defects.
but it sounds like u guys have mod plates or something.... so i'd say call the engineer and ask him.
In all likely hood its hs work that will get you the plates.
Not having experienced with legalities of mods, the only advice I can give you is fix / stamp a reference numbers to the parts requiring certification by an engineer. The Engineer should be able to advise which parts depending on the engineer you choose here: http://www.transport.wa.gov.au/mediaFiles/lic_IB-102M.pdf
It has become apparant that Engineers certification means nadda unless you can prove the certificate refers to the specific part it was intended for. I'd get the engineer to cross reference his certification with the part number you have fixed / stamped to the mods. This will save the headache of argueing with "the plod" that the parts on the car are those that the engineer certified.
As you are fitting a turbocharger to your car which obviously does not come factory on your particular model, you will need to fill out the following form and submit it directly to the Welshpool Technical Section on 21 Murray Road South, Welshpool.
http://www.transport.wa.gov.au/mediaFiles/...orm_prodveh.pdf
If the Tech Section approves the modifications, then you go about having them all fitted and getting an engineers certificate. Once that has been completed, you will need to have the vehicle inspected over the pits for the modifications that have been performed.
As you will be adding a forced-induction unit, there is a very high chance you will need to undergo an emission test, HOWEVER i am not sure if you will need to have the IM240 Emissions test. I did speak to a guy over the phone today who had a HSV GTO Coupe with lumpy cams. He said he didn't have to do the IM240 test but a similar alternative at a business in Bentley (I think?) costing around $100.
Putting that aside, once it has passed the pits and the emissions test, away you go with your newly modified vehicle to enjoy :(
Bolt it on, chances of getting in trouble are slim. Especially in that sort of car, get in the shit remove it and bolt it back on. I turn charged a Magna when I finished school and thought about all the technical shit, if you get a yellow remove the gear and bring it back to stock form.
Ive applied for some crazy idea mods, including a RWD conversion, and theyre actually pretty easy on what you can do, given a green light every time, not that I've followed up many.
It isnt all "legal this and that", as long as they can see quality workman ship, its done properly, and its safe, they'll pass it. There isnt a criteria soo to speak, of what you can and can't do, they'll assess each application for what it is, and go from there. No rule books.
Syfon, tell your bosses that application form is shit...they ask technical questions and give you two and a half lines to explain it all...Epic Fail!
More lines please :D
BTW, dont listen to this "if you get in trouble, go stock, pass, and put it back on" - you could put your gear back on, get 50m away from your driveway and get another yellow - its a retarded idea. Get it licensed legally, they way you want it, and make it look neat, you'll have nothing to worry about.
The probability of been pulled over in a new X-Trail and having under your bonnet checked at ridiculously low, my aunty cruises around in one with her kids. From my own experience I never had any issues driving a higher risk car over about 18 months adding a turbocharger and extra parts which did not come from factory. In all seriousness if you did turbo charge it and the police pulled you over and you had the appropriate information if they wanted to nail you they would. Financially you will save some alot of money. If you have the coin and time the appropriate legal way might be pathway.
Edited by monga
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
