g'day
ive had a starter motor go walk about on me... old man says he gave it to the auto electrician, auto sparky says he's never seen it, you know the story...
Anyway i need one and wanted to know which models of rb starter motors will fit or if there is a aftermarket one that will be a straight fitment
the motor is out of an r34 GTT with a 5 speed manual box behind it (rb25det neo) i know ive got an rb30 one sittin round but im a bit skeptical as to wether it will fit hopefully ill be able to get my paws easily on an r33 one... im gonna try it tonight but see what you guys reakon... ive tried genuine parts from nissan but they want my first born so they can forget it
any help would be great
p.s.
i have also swapped between auto and manual starter motors on the 25det neo and i havent had any problems ( manual starter motor in auto car not the other way around)
Cheers
https://www.sau.com.au/forums/topic/298676-starter-motors/
i think its dependent on the gearbox
if its a rb25 box the rb30 started wont fit, i think that only fits rb20 box
im not 100% sure on any of this though
i would have thought it would be more to do with the flywheel and how far it moves out when engaged... as long as it clears the gearbox and meshes good with the flywheel i should be onto a winner... way better than forking out 1300 big ones for a new nissan one... imagine all the ps3 games i could get for that ha ha
https://www.sau.com.au/forums/topic/298676-starter-motors/#findComment-4969887
finally got a chance to get under my car today... got a few things done, including the starter motor and yes an rb30 one does fit and crank pretty good... beats buying one since i had this one lying round from an old rb30... i should get most of the car done over my month long xmas break :P
https://www.sau.com.au/forums/topic/298676-starter-motors/#findComment-4973315
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
