Hi there!
I have a very strange problem!
I installed a Hypergear ATRG3 Turbo to my ER34 GTT, and from that moment the car stalls all the time..
Also went for a tune yesterday and the car was missfiring from 4000rpm till 6000rpm and then it knocks very HIGH
Like 116!!! That happened twice... So we stopped..
I have Apexi Power FC, Sard 800cc injectors, Sard FPR, Q45 Airflow, Stock elbow, 4" downpipe and back exhaust, 044 Bosch intank, OEM Coils(with electrical tape around them), HKS Iridium plugs(also changed them to Denso IK27), The car was working absolutely fine, before the turbo, injectors and Q45.
Akis.
Edited by Akis
https://www.sau.com.au/forums/topic/298693-bad-missfire-knocking/
I've replaced all the vacuum lines with new ones before the tune(because i thought the idle problem was something leaking)..
The afr's are great and they are not flactuating(when missfiring and knocking) and that is very strange..
Id say its your coilpacks that electrical tape might fix them for when running low boost but when you start putting boost in theyll missfire again thats what happened to me so I just put in spitfires with ngk bcp7es spark plugs
youve changed so many items all at once, it could be any of those
to eliminate the afm, can you go back the std AFM and see if it idles and runs normally with stock AFM
obviously dont load it up, just idle and plod around
if it works, then new AFM is either set wrong, mangled, damaged, wrong AFM or mangled wiring
if it doesnt work (ie problem still present) then youve eliminated the AFM being the cause
i would look at injectors and how they are setup
if the coilpacks are toast, they would have been toast on the standard turbo as well, and it wouldn't make it not idle
No, but my car also used to stall all the time before it was tuned with Sard 880CC injectors in them... :)
It was stalling after i replaced the turbo only(before the AFM and injectors..)
The injectors are set correct, also the AFM is correct..
I taped the coils but i do not know if it is correct, i taped them from the plugs and below the place the screws are..
Should i tape them all the way up?
Also when the turbo was installed one ground(from manifold to chassis) was cut BUT not replaced, could this be THAT bad??
Edited by Akis
coilpacks are a devil of a problem.. that and the ignitor..
it may seem to be running fine, and then you change somethign which doesn't even remotely seem to be related to the coilpacks or ignitor, but they start giving problems.. best yo uchange them and give it a shot..good luck
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
