I was at Chaddy about an hour ago and noticed a few guys walking around the carpark in what appeared to be police unifroms and fluro yellow vests. On closer inspection, they were Sheriffs.
Then I saw a white Camry with UHF antennae on the boot followed by 2 identical cars. The lead car had a camera mounted above the rear door. Had a chat to one of them and it turns out they drive through the carparks slowly and the camera reads number plates, flagging anyone with outstanding fines. They found one next to my car and clamped it. They put massive stickers on the cars windows.
On the other side of the carpark was what looked like a booze bus. They must have been 20 of these white Camrys parked around it.
I guess it's not suprising considering the millions of dollars of outstanding fines. Shopping centres hold a high density of cars and the owners aren't around whilst the clamps are atttached.
Not a bad idea, coz suddenly the tables are turned and now the wanted have to chase up the Sheriffs.
https://www.sau.com.au/forums/topic/298699-sherrifs-dept-blitz-today-chaddy/
  • Replies 60
http://online.fines.vic.gov.au/fines/Conte...=1&l=107-50
"It is a serious offence to tamper with or remove a wheel clamp that has been fitted to a vehicle. The maximum penalty for a first offence is in excess of $6,805* or six months imprisonment."
Also read somewhere a while back that Sheriffs have been advised to take pictures of the cars location when they've put the wheel clamp on to avoid people removing them and denying that the clamp was ever fitted.
Just spoke to a mate who is part of the operation at the moment. He drives one of those camry's daily but it doesnt have the camera in it.
But they all carry wheel locks. I must say though some of the stories he has told me and the scum he deals with I don't blame them for doing things like this.
He has this huge folder of names, listed in priority and he just works through them...
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
