Passenger Indicator
Climate Control unit
the plastic part with ashtray, not sure its Center Dash Trim or Gearshift Surround
how much for all these and post to MEL?
Cheers
Bruce
can i have your number? i cant pm, sorry.
  • Replies 102
Posted Images
Updated... Feel free to ask for anything else not mentioned
Engine/Mechanical
Plenum & Throttle Bodies $300.00
Standard Block $700.00
HKS 2530 Turbos approx 10,000k's old $2,500.00 including HKS actuators and HKS dumps
Exhaust Manifolds $50.00
AC Compressor $120.00
Power Steering Pump $100.00
Alternator $50.00 pending
AAC $50.00 pending
Coil Packs x6 $100.00
Ignitor $50.00 pending
Covers (minor crack on front cover) $300.00
Crank Pulley $100.00
Turbo Oil Water Lines $50.00 SOLD
CAS $120.00 SOLD
Tomei Camshafts $500.00 SOLD
Greddy Cam Gears x2 $200.00 SOLD
Windscreen Wiper Motor $40.00
Brake Master Cylinder $50.00 Pending
Clutch Master $50.00
Boost Sensor $30.00 SOLD
FMIC Piping x4 $80.00
BOV x1 and adaptor plate $50.00
Cross Over Pipe $50.00
AFM's x2 $140.00 (2 Sets) 1 set left
Gearbox $500.00
Front Diff/Sump $300.00 HOLD
Power Steering Reservoir $30.00
O2 Sensors x2 $50.00
Engine Wiring Loom $200.00 HOLD
Injector Resistor Pack $50.00 Pending
Fuel Rail $40.00
Clutch and Brake Pedal $30.00 each Pending
Accelerator Cable and Pedal $50.00
Windscreen Washer Bottle $30.00
Front Driveshaft $40.00
AC Condensor Fan $20.00
Standard Clutch Fan $40.00
Starter Motor $100.00 pending
Interior
Dash Cluster 280kph (No Brand) $150.00
Front Seats (wear on driver side seat) $500.00 (pair) hold
Rear Seat $100.00 hold
Momo Steering Wheel & Boss $50.00 SOLD
Instrument Cluster Surround $30.00 SOLD
Door Cards $60.00 SOLD drivers Passenger side left
Dash Loom $100.00
Carpet $80.00
Roof Trim $80.00
Center DIN Guages $80.00
DS Window Control $60.00
Sun Visors $30.00 Pending
Boot Trim $50.00
KickPanels $30.00
HICAS Computer $50.00
Gearshift Surround $40.00 Hold
Center Dash Trim $40.00
Rear 1/4 Trim $40.00 SOLD
A Pillar Trims $30.00
Center Console $60.00
Door Garnishes $50.00
Interior Lights $30.00 SOLD
Dash Windscreen Demister Vents $20.00
Glove Box $30.00
Fuse Box Cover and surround Interior $30.00
Drivers Footrest $20.00
Heater Unit $40.00
Climate Control unit $80 pending
Suspension & Brakes
Brakes & Rotors $500 Hold
Front Driveshaft $100.00
Brake Booster $30.00
ABS $180.00
Tailshaft $150.00
Steering Column $150.00
Steering Rack $150.00
Exterior
Passenger Side Headlight $120.00 SOLD
Boot $100.00 Pending
Passenger Guard $100.00 Hold
LHS Door $130.00
RHS Door $130.00
Windscreen with RVM and in built antenna $200.00
Rear Window $150.00 Hold
Sideskirts $50.00 Pending
Wiper Arms $30.00
Fuel Tank $150.00
Tail Lights $50.00 each
Genuine GTR Rear Wing $100.00 Pending
Passenger Indicator $20.00
Rear Bar reo $50.00
Cowl Pane l $40.00
Reverse lights $30
Clutch lines $40
Side mirrors $50 each
Rear Bumper $80
Hey im interested in the Carpet, center glove, side skirts and side mirros can u pm me the prices shipped im ready to buy them asap thanks
Hay mate,
Side skirts and mirrors gone mate but glovey and carpet still avail. Send me a postcode for an accurate price via email [email protected]
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
