  • Replies 102
Posted Images
Hi mate, I sent a PM a week ago asking about some interior trim parts...
Anyway, I want the Centre dash trim please, send me a msg on 0411 544 307 to say when I can pick it up. Need it before Christmas.
And if you've got the shifter boot square in good condition, I'd like that too please (that the boot clips into).
  • 3 weeks later...
New update... May parts up for grabs again due to deals falling through
Engine/Mechanical
Plenum & Throttle Bodies $300.00
Standard Block $700.00
HKS 2530 Turbos approx 10,000k's old $2,500.00 including HKS actuators and HKS dumps SOLD PENDING PAYMENT
Exhaust Manifolds $50.00
AC Compressor $120.00
Power Steering Pump $100.00
Alternator $50.00 SOLD
AAC $50.00
Coil Packs x6 $100.00
Ignitor $50.00 SOLD
Crank Pulley $100.00
Turbo Oil Water Lines $50.00 SOLD
CAS $120.00 SOLD
Windscreen Wiper Motor $40.00
Brake Master Cylinder $50.00 SOLD
Clutch Master $50.00
Boost Sensor $30.00 SOLD
FMIC Piping x2 $40
BOV x1 and adaptor plate $50.00
Cross Over Pipe $50.00
AFM's x2 $140.00 (2 Sets) 1 set left
Gearbox $500.00
Front Diff/Sump $300.00 SOLD
Power Steering Reservoir $30.00
O2 Sensors x2 $50.00
Engine Wiring Loom $180.00
Injector Resistor Pack $50.00 SOLD
Fuel Rail $40.00
Clutch and Brake Pedal $30.00 each
Accelerator Cable and Pedal $50.00
Windscreen Washer Bottle $30.00
Front Driveshaft $40.00
AC Condensor Fan $20.00
Standard Clutch Fan $40.00
Starter Motor $100.00
Interior
Dash Cluster 280kph (No Brand) $150.00
Front Seats (wear on driver side seat) $500.00 (pair) SOLD
Rear Seat $100.00 SOLD
Momo Steering Wheel & Boss $50.00 SOLD
Instrument Cluster Surround $30.00 SOLD
Door Cards $60.00 SOLD drivers Passenger side left
Dash Loom $100.00
Carpet $80.00
Roof Trim $80.00
Center DIN Guages $80.00
DS Window Control $60.00
Sun Visors $30.00 Pending
Boot Trim $50.00
KickPanels $30.00
HICAS Computer $50.00
Gearshift Surround $40.00 SOLD
Center Dash Trim $40.00
Rear 1/4 Trim $40.00 SOLD
A Pillar Trims $30.00
Center Console $60.00
Door Garnishes $50.00
Interior Lights $30.00 SOLD
Dash Windscreen Demister Vents $20.00
Glove Box $30.00
Fuse Box Cover and surround Interior $30.00
Drivers Footrest $20.00
Heater Unit $40.00
Climate Control unit $80
Suspension & Brakes
Brakes & Rotors $500
Front Driveshaft $100.00
Brake Booster $30.00
ABS unit $180.00
Tailshaft $150.00
Steering Column $150.00
Steering Rack $150.00
Exterior
Passenger Side Headlight $120.00 SOLD
Boot $100.00
Passenger Guard $100.00
LHS Door $130.00
RHS Door $130.00
Windscreen with RVM and in built antenna $200.00
Rear Window $150.00 Hold
Sideskirts $50.00
Wiper Arms $30.00
Fuel Tank $150.00
Tail Lights $50.00 each
Genuine GTR Rear Wing $100.00
Passenger Indicator $20.00
Rear Bar reo $50.00
Cowl Pane l $40.00
Reverse lights $30
Clutch lines $40
Side mirrors $50 each
Rear Bumper $80
Was that the bar that secures the battery in one of the pictures? How much :huh:
Haha, sorry mate, i think that is the gearobx sub-frame u might be looking at. The battery tie down got a bit bent in the accident.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
