  • Replies 425
spotted trust6 hammering it down main north rd, turned off of research rd :D about 5.30 yesterday.
WTF!? Dean there must be two of 'em!!! Mine was safely tucked away in the garage at that time, well I sure hope it was!? I didn't even get home in the Sigma till 7pm. No one else (and I mean NO ONE!) has a spare key.
Besides I wouldn't hammer it on Main North, I'm a good boy :thumbsup:
i saw a R33 gtst in melton redish with gold wheel that blew away GTR 34 and GTR 33 kleend both of them up the car looks stock as a rock sounds smooth not nosiy at all not a lump in it he poped his bonnet and it look stock as a rock then he turn around and said the hole guts of his motor was built by nismo and has about 380 rwkw at no sweet i cant belive my eyes on this car it well shock the lot of u keep an eye out for it it as interstate plates on in but it lives in the melton some where
hehe hot blonde? was prolly one of Miss*33's friends!!!
Well it definitely wasn't my car cos I wouldn't go near town on a Friday night unless I could help it. Plus my car is a Series I!
I do have a blonde friend who has a white 33 though, AVS wheels, GTR front bar - could have been her... but hers is a Series I too... :confused:
not at all, just have some trouble believing it when it looks "stock as a rock"
I would love to see it done. I do find it hard to imagine how you can get a stock looking turbo to make that sort of power - then there is the stock manifold - big restriction, stock plenum would be pretty restrictive too, not to mention the stock TB.
then there is 'sounds smooth, not noisey' well I found the nismo 3" exhaust, which wasnt that quiet at full song, became quite a restriction at anywhere above 285rwkw, so I would love to know what he is running. If I can make power with a quiet exhaust I am all for it - less attention.
I seriously would love to see this car.
the 400r is an rb26 and was supposedly 400bhp - who knows, not too many people actually own them:). Nismo do make crate engines AFAIK, but you still need all the support systems to make it work. The performance is only ever as good as the weakest link, whatever it may be.
don't think nismo's engine will be such hardcore, they are all about 'balance' but not high power.
even a 400R will find very hard to acheive 385rwkw if he don't mod it.
400R is only using nismo N1 engine with full fogre internal (piston, rod, crank shaft) and 2 x N1 turbo, which u can buy from nismo today as well, the only think special is carbon fibre drive shaft and it was totally built by nismo with limited number.
Correct me if i'm wrong but wasn't the 400R a hybrid type of motor with a 2.8ltr Mill in theory a RB28?
and the chance of someone owning a 400R here in australia would be unlikly......
It would be like the most known thing in SA/Australia/Import Community those car's r as rare as tits on a bull
something like only 100 made and i also read things like u cannot even buy a gunuine 400R
with out actually owning a car, jsut showing how serious the exclusivity of the car is and
how seriously NISMO take it.
BUT yes if is a 400R by some slim chance then show me to it wid camera in hand :)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
