think your right about the 400r being an RB28 or something - I probably would have been better off saying the 400r is a limited edition GTR:) very very limited.
But Nismo do sell crate motors, so you can buy a fully prepped engine off them, I have only seen them in RB26 form though.
Maxx, only using fully forged and balanced internals eh? how weak:p But seriously, this is how RB series make good power, built the bottom end tough, balance it, bolt on the good bits and rev the tits off them. I think the initial limiting factor is the turbos in the case of the 400r. Intercooler might not be helping either if it is a stock GTR item.
  • Replies 425
Saw whatsisname on NE Road this afternoon while I was with a friend from work looking at 33s. Can't believe what hefty prices they're asking for some of them at the moment - more than what I paid 2 years ago. Plus they were all older and had higher kms... :blah:
yeh i recon i saw him also
i was sitting in the car park next to motor city talkin on my phone
in my r32 and the guy from motor city came out and asked me if i wanted to
sell my car
apparently he is finding it hard to get r32's in his yard
i said no coz i would only have to replace it
and its better the devil you know i think :devfu:
Yeah I went and washed the car at the car wash on NE and then headed out to AIR.
Would you believe me if I said the Sudholz move was very out of character for me Pawley? :D I was just warming up for AIR....hehehe My exhaust is still quite restrictive but I'm not game to open it up anymore than it already is. Thanks for the feedback on how she sounds mate!
I want the black NSX at Motorcity - screw the crappy 350Z :)
I didn't even see the NSX until I drove back the other way later on. It did look very sweet though - then I saw another black one driving along NE Road about 2 minutes later. Not very often you see them around.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
