Hi,
I'm about the have my MR30 parts car taken to the wreckers, what I'm wondering what small parts are worth selling, the reason I said small, is that I live in Tasmania, so freights on larger parts would be to expensive.
I also may try ebay to sell some off it, but since I'm never sold anything on ebay, I'm not sure what the expect.
Nigel
https://www.sau.com.au/forums/topic/299067-mr30-what-parts-are-worth-selling/
Hi,
Nigel
Hi Nigel,
Try posting a list of (both big and small) parts here, there could be some interest. Also, where are you in Tassy?
JohnH
juast think of anything that can break, like all switches, handles, knobs.
all glass
lower control arms
panels
bonnets
dissy can fetch $200, Ti rims can get up to $60 each,
if the interior is NOT brown keep as much as you can.
Heater core is another item I have replaced
Handbreak cables sieze so keep them
the only problem it comes down to is storage of it all....
Like Mags said the Dissy is the big one. The big 15/16 master cylinder if it has rear disks. Rear calipers. Speedo cable, bonnet and boot cables all break. Engine timing cover if it hasn't corroded. Put the diff and half shafts away for a rainy day or a Tassie local. I've also replaced a heater core...
I've pulled the rear diff assembly (whole trailing arm assembly), front stearing assembly (including struts, brakes, power stearing box / pump), cross member, engine, badges, stearing colum, swaybar, and also got the master cylinder / brake boster
I'll need to get the locks, heater core, cables, tail lights / headlights, as for the pannel, I have no where to store those parts, It's a pitty since there is nothing wrong with them.
the dissy was one of the first thing I took, aswell as the whole EFI that I put into my 240K years ago (the reason on buying the car n the first place), but since moved onto Megasquirt
Nigel
Edited by noddle
Hi Nigel,
You say panels are in good condition. Could you post some pics of the car please? How many k's on the clock? Auto/manual?
I'm interested in tie rods if the bushes are in reasonable condition. Maybe some other bits too.
JH
Nigel,
Near on everything mechanical & electrical is good to sell. Ebay is a lucky dip, you can get a sqillion for some things and SFA for others and usually the opposite to what you are thinking. Genuine Ti rims are a good seller & for everyone out there Stewart Wilkins will pay reasonable dollars for all he can get. He uses them on Zed rally cars he prepares, as one car might go out with 4 or 5 sets of rims. Rear trailing arms, especially disc brake models are a good spare as they can get bent, fronts don't worry about as the new Taiwan option @ about $70 each is a better deal.
As has been suggested, put up a list of what you have or are prepared to pull off and let whoever pay the freight if they want it badly enough.
The guys on this forum know I buy near on everything R30 off ebay, that I don't have already for spares as the plan is for my PNV to stay in the family for generations to come. My 24yo daughter has already put her hand up for it when I'm dedd and I'm sure my son would do the same.
Cheers, D
Hi Dennis,
Can you post some details or links about this please?
John
John,
Just walk in to ANY of your local parts outlets, Autopro, maybe Repco, Auto One, Pep's etc etc and ask for MR30 front lower control arms and specify the Taiwanese Import and they will get them for you. I will post pics and part numbers on packs later when more time.
Cheers, D
Cheers, D
Here's 2 pictures of what the body looks like, it is a Automatic, box is still in the car,
Dash has been pulled out, but is still sitting inside the car, seat are still in the car, drivers side runner were 'hacked' to fit something else, heater box still in car, less the copper pipes that connected to it. rear seat still in car,
all electrical wiring is missing, engine / efi exhaust, rear suspension , front suspension, cross member, brake booster, master cylinder all been removed,
If some one want some thing, and its worth my while to remove, I can, but be aware I'm in Burnie, Tasmania, so fright on large items will be a killer, and bits can get damaged in freights (like body panels)..
and I do work full time, so the week end is when I get stuff done.
Nigel
WOAH! looks loke gagebrook not burnie!!!
Atleast there aint no skid spec XD falcoon!!
D-Limo might be interested in the front stone tray (lowest part on the front)
Im interested in sending you that stuff too, might swap it for a neatly done RB30 to L24 fuel rail??
Here's 2 pictures of what the body looks like ...
Hi Nigel,
Thanks for posting the pics. Panels look good (and it's hard to find good panels once a car gets to the wreckers). I guess you already have experience with freight costs. I checked out some pricing. Pack-send was really expensive since they direct everything through Hobart! TasFreight quoted $135 per cubic metre (depot-to-depot Launceston to Melbourne, exc gst and no insurance) and then there's all the hassle of packing and transport.
(Still looking for tie rod ends).
cheers,
JohnH
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
