  • 3 weeks later...
Hi,
I put up a MR30 Fuel Flap / Door on ebay today, item number 180454298440
maybe some one can tell me why I can't find it when I search using some keywords.
my first try with selling on ebay. still not sure what I'm doing :-)
Dennis, I put that "steering box", into a box tomorrow, and find out what its worth to mail to you
Nigel
Hi Nigel,
The search is working now. I assume it takes some time for the keywords to be indexed.
Was the postage 'reasonable' for a steering box?
cheers,
JH
Hi Nigel,
cheers,
JH
I will be checking today, Had to buy a puller, to get the steering arm of the box (it still had the entire steering linkages attached). very tight.
Nigel
This didn't sell,
so I'll get one of the metal merchants to come and collect the car next week, it's a pity since the body's and glass is in such good shape.
I don't really have the time, or the energy to play with ebay
Nigel
  • 4 weeks later...
if i remember correctly the N47 has 8.7:1 comp, and the E88 has8:1 or near to that... E88 flows higher CFM too.
N47 on dished pistons with a T3/4 turbo .50 in, .63 exhaust, that's what I'm running now.
since I've never seen a P90 head, this is my next best thing.. peanut shaped combustion chamber to help with swirl, dished pistons to drop the compression ration, and once I un-shrouds the valves, it should add a few more cc to the head.
I'm going to build a L28 with a N47 head (reason I'm after a second head), maybe put the larger valves in, haven't decided yet, as it all comes down to cost
Nigel
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
