hey guys i have a r33 gts t that has a stuffed clutch it slips in 5th and 4th apparantly they put a heavy duty clutch in it before i bought it ? would leaking crank shaft seal cause it to slip ?
has anyone heard of rpm clutches ? are they good
i have aftermarket comp 3 '' exhaust 12 pound of boost i dont wana spend a fortune on a clutch i also have 265 tires on back with soft tyres
can anyone help me thanks
dan...
https://www.sau.com.au/forums/topic/299123-skyline-r-33-clutch/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
