hey everyone,
the car is blowing white smoke on heavy decel and if im just crusing around with out coming on too boost
and change gears it gets a very small puff of white smoke, i had a comp test on the w/e before we dynoed it
with interesting results
1. 165
2. 175
3. 180
4. 175
5. 175
6. 180
when we removed the plugs there was no sign of oil(or burning oil) on any plugs they were very clean and even burning
my tuner seems to think it s turbos??
is it possible to be valve stem seals??
it doesnt blow any smoke on start up or if its been sitting
i tried searching for the results but nothing that helped me out
russell
Edited by RUSSMUSS
https://www.sau.com.au/forums/topic/299132-r32-gtr-oil-smoke/
Possibly stem seals...... After a decent drive try pulling over and leaving car to idle for a couple minutes. Then while watching in the rear view give it a swift rev up to say 3000 rpm and off. Will it give a puff of white smoke on revs declining ?
hey everyone,
1. 165
2. 175
3. 180
4. 175
5. 175
6. 180
russell
How old or new are your turbos?
its going to be the rear seal on one of the turbos. oil is passing the seal when there is no back pressure in the rear oulsing. oil pressure is overcoming the pressure in the housing and then a bit of oil passes the seal and smokes in the hot turbine housing.
I had this happen with the last turbo I bought. I rebuilt it myself and no more smoke
cheers!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
