Also funny how most said drag cars have double the ci except for the rotor's
And up to and over 5000bhp, multi stage clutches, full chromoly chassis and running on nitro methanol.
as apposed to this
  • Replies 115
or people could be talking about circuit racing as opposed to drags??? =\
horses for courses..
+1
I've just finished the manual box conversion to my Stagea. Next step is a brake upgrade, then I'll be hitting up Mallala for a track day.
Anyone wanna see how fast a "Volvo wagon" can go :)
+1
Anyone wanna see how fast a "Volvo wagon" can go :P
didnt someone else have their 260RS out on the track day....that went alright
will find the consult port, got to use my laptop as speedo for a little while
until I fix up the connection to the tomei dash
If your speedo cable isn't connected to the dash then your laptop will not display speed - the sensor is in the speedo head.
I can run my car in both and 4WD is a f*kton better than RWD. RWD = wheel spin/limiter bashing at full boost in 1st & 2nd which = slow and gay, 4WD = over 300kw of traction and that throws you back in the seat like a mofo ;) No way in hell i would ever trade mine for a 300kw GTST.
Mine still spins and limiter bashes in 1st and 2nd..........in 4wd :P
its already an animal whats next :P
merry Christmas too Andrew will ring you soon about the simulation day would be good to see you in that
Cheers Steve, Merry Xmas to you too! I'll have to see whether I'm about for the Simulator day - already spend lots of time in sims.... but would love to come along!
as apposed to this
2 litre SR20VET; 7.49 sec and the RWD's have it. Oh and that was the first full run ever in the car it running better times now.
Yeah, but yours is also running 1'15 around Mallala lol
Hmm, now I'm wondering if I'm faster around Lala with the 60hp proddie, or the Stagea! :( I've done 1m17s with 100hp.
Yes, I'm cheating and talking bikes again. :)
Remove slicks and replace them with street tyres and also take away the drag strip and put them on the street and the 4WD will kick ass!
Pretty sure we were talking about street cars driving on the street to start with were we not?
measure them, unless they are 296 x 32mm then they aren't GTR. R33 GTS-t's are the same diameter but 30mm. The regency inspectors will know the difference.
Oh and by the way the quote for the engineers report mentioned in that statement was $2500
dale you can fit 32 mm gtr discs under r33 calipers, I have done it on my bluebird. Inspectors wont know the diff, mind you gtr calipers arnt that expensive anyway. Also i loled at fitting r33 power steering.
selling the wheels and tyres it came with.
selling the 5-seats
selling the spare gearbox - we'd need to see if it is indeed a spare gtr box. its sitting in the boot still :D
pm me for details
great fun to drive, going to be heaps awesome out as a dedicated mallala track-biatch
cheers all
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
