Basically my heater smells like urine...bad....the musky cat piss type of urine. Has anyone else had this or know how to fix it?
I would assume some sort of bacteria build up? It only smells with the aircon off, if i turn on the a/c then it doesn't smell but as soon as the a/c is off and its running off the fans/heater (regardless of temperature) it will stink.
Help pleaseee!
Cheers
Dom
I was also thinking cat piss hahahaha..... there are a few types of deoderiser you can get, but you may have to actually replace the piping in behind the dash if they don't help... :)
According to the R34 Owner's Manual (-yes there IS a genuine one in English)
...the "Air Ventilation Filter" is to be replaced every 20,000Km.
How to get at it, is in the R34 Workshop Manual (on SAU here via 'search' or on disk).
I'm going to try take the filter out to see if it is the problem, but can someone please tell me how to actually get to it?
I looked in the r34 workshop manual but it only says how to take the filter out....not where it actually is and i have no idea.
thanks
thanks
Behind the glovebox I beleive
thanks for that, will check it out tomorrow =]
I want to check mine out also but the service manual looses me with the first removal instruction---
1/"remove the instrument lower assist panel"--i would absolutely love to --if only I knew WTF it actualy is .
2/"remove the clip and remove the cover" I still aint got past 1/
3/"Remove the deodorizing clean filter assembly from the blower and cooling unit"---farkit, I'm goling for a drink---.
how did you go with yours ? :)
haha yeah I was like that at first, but eventually worked it out.
1. remove glove box. There are 2 sliding clips at the bottom of the box (stick head into the foot well to see them), you slide them and pull them out, that will let you take the glove box out. There is a retracting cable that is attached to the right hand side of the glove box, that needs to be slid off to let you remove the whole box.
2. remove all the screws behind the glove box, including the clip that the box grabs to in order to stay shut. Can't remember how many, probably 4 or so. This lets you take the whole panel off and reveals the aircon blower and filters.
3. locate the rectangle white plastic thing. there is a metal clip on the bottom, take that off. then slide the whole plastic thing up and that allows you to take if off.
4. now the white plastic rectangle thing is off, the filters are revealed.
unfortunately they weren't the source of my urine smelling heater :bunny:
unfortunately they weren't the source of my urine smelling heater :)
Thanks very much for that.
Mine smells like an oriental knocking shop , quite pleasant actualy , so I'm guessing that the filters were new in Japan before it was imported or were renewed by the dealer prior to it going on the yard, so it may have formally been a cats piss percy . What was the stinko with yours anyhew ?
How much were the replacement filters ? -if you don't mind me asking.
You could try spraying Glen 20 into the intake with the fan on full, if its fungal/bacterial thingo that may get it ? just a thought.
Edited by BASHO
Hi, my mums car had the same prob.. I don't think it's bacteria problem n doubt it really is cat piss! It's the heater core, most likely leaking n will affect electricals too like cd player and etc.. Mist change asap before problem branches out. What ur smelling is actually the burning smell of leaves that actually got into ur engine bay which prob contains animals piss.. Let me guess, ull find it hard to get rid of mist from ur windscreen too? If yes then u r experiencing the same problem. Anyway I could b wrong but get it checked out soon..
So turns out that the source of the smell wasnt the filters and there isnt a problem with the heater core from what I can tell....this mystery continues =/
If i were to try and spray in some sort of glen 20 or disinfectant, where would I spray this? Maybe that will solve it...worth a try since we always have that stuff hanging around the house
Just guessin but you could maybe try taking out the filters, running the fan full tilt and spray the Glen 20 in the hole where the filters should be, I'd only be giving it a bit of a hit at a time just in case theres wireing / electricals that might not like getting soaked.
Hey Dom, you spray ur disinfectant or scented spray in and around the intake vents on the scuttle panel, which is located at the bottom of the windsreen, below wiper arms
If that doesnt work, You can also try what they call an AC Bomb, which is a can of disinfectant which u place on the passenger floor mat and release the valve while having the car running with ac on recirc for 10mins or so. As the heater and ac use the same ducts. I t will kill any bacteria or smell in car, After the process has been done is has a sterilised clean smell.
A little random but does it go away after a while? I had a similar issue in the Ford and its actually something weird that someone put in the washer bottle that goes off, after using the washer on the windscreen a terrible smell comes through the vents of the car for ~5-10minutes then goes away.
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
