both are 4 pot, but gtr has bigger 4 pot and they are made by brembo! also the GTR caliper allow u to take bigger dimmeter rotor.
most 2 hand gtr brake are bit over priced IMO as they are 5-7 years old and go for around 2g. for about 3g u should able to get a set of brembo brake kit which come with "brembo drill" rotor, braid line, the lot. And u can choose the color u want as well.
Just a quick question. What is the difference between the standard gts-t nissan calipers and the gtr brembo's, they are both 4 pots ain't they? and is it a worth while upgarde?
All are 4pot.
R33GTR/R32 GTR (VspecII) are 326x30mm
R32GTR (Non-vspec & VspecI) are 296x32mm
R33 GTS-T are 296x30mm
HTH.
C.
I have never driven a GTR and I have never driven a car with Brembo brakes but I would say from my own opinion that it is not a worthwhile upgrade. For a set of front calipers and rotors you would be looking at around $2,000 and you certainly are not going to get $2,000 of better stopping power.
If you plan on using your car at the track often (ie; more than 4x a year) then sure it may be worthy of upgrading to Brembo's as they will give you much more consistent braking abilities over the standard system.
For a fraction of the price you could get a complete DBA setup and I honestly don't think you would notice the difference.
I agree with benm, If you add a decent set of rotors (eg. DBA 4000s), good fluid, good pad (pick one, everyone got a different opinion on what are good pads) and some braided lines and you will have more than enough stopping power for less money than upgrading to brembos then getting good pads, fluid, lines. Unless you take you track work very seriously the above upgrades will do fine.
some interesting stats in this thread re stock vs upgraded brakes....little difference in stopping distance for one off stops....they only make a big difference over repeated stop/when hot...
*edit* and here is that thread
http://www.skylinesaustralia.com/forums/sh...ead.php?t=28354
I was quoted $700 for a set of GTR 4 pots.
+ the rotors would most probably set me back in total $1000.
R32 GTR 4 pots are no bigger than R33 GTS-t which can be had for 550 secondhand with disks if you look around.
BTW R32 Vspec 1 disks are closer to 305mm diameter
The pic is 32GTSt compared to 32GTRVspec1 (don't mind the writing on them)
Hi guys, we use R32 GTST M Spec callipers and DBA slotted (never drilled) rotors with Hawke Carbotic pads on our circuit race R32 GTST with RB31DET. The limit of stopping power over a 20 minute race is the tyres, not the brakes themselves. I can lock front or rear brakes on demand, on the last corner of the last lap if I want to. We use the soft compound Yokohama A032R's in 245/45/17, so they are plenty sticky. Unless you are using slicks, I see no reason to go any larger in brakes.
At 1200 kgs the R32 GTST has a fair bit less weight than a GTR, so there may be a case for upgrading if you are over 500 4whp and/or using slicks. But I would be very carefull about jumping straight there. I think you would get better lap speed for your money by spending it elsewhere.
Hope that helps
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
