sup guys as you could probably tell from some of my recent posts, that im pretty new to this skyline car shagizmo thingy anyhoos, i was thinking of looking for some extractors for my car what will they do exactly? in conjunction with a new exhaust? and where abouts can i buy them from?
cheers jarrod :(
https://www.sau.com.au/forums/topic/299722-r34-extractors/
cheers jarrod :(
www.wikipedia.com or top right hand corner search , there are plenty of threads about extractors if you look
https://www.sau.com.au/forums/topic/299722-r34-extractors/#findComment-4981247
In Australia, it's either custom made, or get them from DKNE (Dumper King n Exhaust).
Unless you're willing to import them and get the tried & tested Coby Extractors from Parts Co in New Zealand.
Good idea to get them HPC Coated also and shield them from your air box...I forget who it was on here who had extractors melt through the airbox.
With DKNE you can pay for the optional Flange to be able to simply bolt on without welding.
RB25DET doesn't use extractors. On the N/A RB's the extractors dump to a front pipe, to the cat and then the catback. On Turbo RB's the turbo manifold replaces the extractors and the exhaust gas drives the turbo charger exhausting out the back of the turbo through the dump and front pipe to cat to catback. Very different concept.
https://www.sau.com.au/forums/topic/299722-r34-extractors/#findComment-4982133
i have a set up for sale at the moment mate. when i had them on my 25DE they made a noticable difference, especially in responsiveness and high end power, really opened things up...they were on an R33 but im pretty sure they bolt straight up to 34s aswell. make sure you have a catback to go on down the track too. that combination never fails to work wonders :laugh:
mine are cobys, all flanges are on and ready to bolt on.
$250 and theyre yours.
https://www.sau.com.au/forums/topic/299722-r34-extractors/#findComment-4990707
Put them on my Supra and I honestly didn't feel any difference. Apparently they're good for 15-20rwkw on the 2JZ-GE (not JUST the extractors, this is stock exhaust to full custom exhaust), but I like I said I didn't notice it.
Once I replaced the exposed pod (this is after the exhaust) with a stock box and aftermarket panel filter I did notice a significant boost to power, although nothing spectacular.
Point I'm trying to make is unless you're planning on taking your car to the track, drag strip, etc and really want to squeeze every watt of power out of it, I suggest you don't do it. It's expensive for very little gain. Put your money towards cosmetics or save it for when you get off your P's.
Although one great thing about the extractors (at least on the 2JZ) is it makes the exhaust note sound awesome. Very high-pitched, racey and unlike 90% of the deep and "droney" import cannons out there.
https://www.sau.com.au/forums/topic/299722-r34-extractors/#findComment-4992557
i have a set up for sale at the moment mate. when i had them on my 25DE they made a noticable difference, especially in responsiveness and high end power, really opened things up...they were on an R33 but im pretty sure they bolt straight up to 34s aswell. make sure you have a catback to go on down the track too. that combination never fails to work wonders :P
is that delivered?? if so, definitely keen
https://www.sau.com.au/forums/topic/299722-r34-extractors/#findComment-4997134
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
