Hey Guys.
Just another quick question before i bolt the new turbo in place. My factory Manifold is looking a bit worse for wear (Not leaking or anything though). Corroded away along with most of the bolts in it being stuffed. (Part of being 13 years old i guess)
Option 1 and the easiest - Leave it there pretend it isnt corroding and worry about it next time there is a problem. (maybe something could spray with to help protect the new bolts i will be putting in??)
Option 2 - Take it off (will be a nightmare i am sure) And replace it with a new Factory piece. If this is the case would it be well worth looking into ceramic coating? and would there be anything else you can do to improve the factory manifolds performance.
Option 3 - You tell me what this option is. If replacing with a non factory manifold it would have to line up like factory on both ends as well as sit in the factory location. i have ZERO interest in a himount setup.
Cheers for any help.
Luke
https://www.sau.com.au/forums/topic/299767-stock-exhaust-manifold/
Are you talking just some surface rust?
I cant imagine it being much more than that, which is nothing at all to worry about.
The manifold bolts - this is common after 10+ years. Just replace them with better studs and away you go mate.
You'll probably break a few, its easier to call a mobile thread dude to get them out - trying to do it yourself is the pits
If your super worried about the rust, get it sand blasted. Then ceramic coat it if you want it to be pretty.
I'd also port match the thing to a set of new gaskets, then clean up the casting marks etc ( on the inside ).
Edited by XRATED
Yeah its just surface. Just whilst i have access to it i might as well find out if theres a better alternative. i.e the caramic coating that will be better for me in the years to come
better in what way? :ninja:
performance - no real gains at all to coating, porting etc. Just added expense for a gain that is debatable.
It's a factory manifold which im assuming has a factory turbo (or similar small item attached).
looks - well coating or something will make it look better... but then you have a heat shield over most of it so unsure what advantage that has at the end of the day as you should always run the heat shield
Located in Bendigo Central Vic.
Thanks for answering. I shall stick with the existing manifold as it is at the moment, except with some new bolts. Yeah i still have the cover so im not fussed at all with what the manifold looks like.
Concern Solved.
Luke
Theres a tool you can get that makes it very easy
i think its called a thread puller or stud puller, can get it from repco, never know when it will come in handy
How long does it take to go back to the way it was?
6 months?
was that a question for me. if so sand blasting is a surface preperation. so all depends on if it gets coated or not.
generally most people just want the surface cleaned up and thats it.
Just wondering how long it takes before it goes back to what it was like before :rofl:
Debateable. I know there are easy outs etc.
But read the threads here about people that have attempted this alone, and ended up calling someone out the next time etc.
It costs very little per broken stud. Consensus usually seems to suggest pay the $100-$200
yeah good question, like most mild metals left uncoated they will rust, touching the steel with sweaty hands will bring
the rust on quick. i would say you would get 6-12 months on a exhaust manifold before it rusted again. but if you lived
close to salt water that could speed things up.
I charge around $40-$50 per broken stud. that's the price if you dont touch it, if you have had a go and cant get it you could be looking
at around $60 a stud depending what you have done, and if you have snapped a drill bit or easy out in there as well,expect to pay around
$100 a stud. and these prices vairy depending on the access to the stud as well.
Edited by boostn32
gotta love it when they dont tell you that they already snapped an easy out in there makes you just want to smash skulls sometimes!
So so true, only one word comes to mind when you see someting else snapped off in there, F*#K
haha yeah, thats the one word that gets said after the whole "what the f$$k, why isnt this working like normal, that should be coming out, what the f$$k is that there, Ahh F$$K" than its followed by "useless F$$king c$nts that don't know what the f**k there doing"
oh the joy of it all lmfao
Edited by Cartman
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
