I was browsing through the various forums and things on the e-manage and appart from it having rave reviews, even from dumb ass yanks, I encountered what I thought was a file of actual screen shots from the software.
I thought 5odd meg was quite alot of screenshots to have in a zip file and after downloading the file I found that I had just aquired the full version of the software!
I don't own the e-manage (yet) so its not of any real use, but what a great peice of hardware that thing is for the money. The software alludes to the real power of the package. For anyone thinking about a new ECU, go check out what this thing does its great!:D
https://www.sau.com.au/forums/topic/3000-e-manage-looks-the-bomb/
Originally posted by EVL R33
Rev,
Where did you download the software from??   A couple of mates have them installed and might be interested in the software for their laptops
Brett
I was looking this morning and the site has removed the link, I still have the software so I will transfer it to cd tomorrow. What sort of results did they get with their e-manage running in AFC mode?
Rev,
Not sure about the AFC mode thing, but both guys have 180sx's with SR20DET's, one has a GT25 and the other has a GT30 turbo, both have upgraded fuel pumps, FMIC, full zorst, the usual stuff. The GT25 now has 275rwhp with the emanage and the GT30 has around the 320rwhp.. Both has stock internals too...
I was thinking about going the emanage, install and tuned for around $1,200, but I'm leaning towards a Power FC with H/C for $1,450..
Brett
Originally posted by Pva_Glue
is this real management system?
or
the program gives you the power figure of your car accoring to your MOD installed...
well my mate has simmilar program.
YES YES you SMOKE IT (I mean read it) then PASS IT on!!!
cheers
Joe
Ok:rolleyes:
Yes its a real program to go with the e-manage piggyback ecu. Upgrades the $405 e-manage AFC functions to full 3D timing/fuel map, with real time data logging tuneable through a PC. With more options than you can poke a stick at.
The link is down but I have put the program on a CD
Hopefully my e-manage will be fitted this week or next.
I've got the full options but have had to wait for the software to arrive in aus.
Unfortunately you need more than just the software to realise the full potential. There is a special cable to connect to your laptop. It looks like a std type of connection but isn't.
Will let you know how it goes.
PFC was my first preference but they're not available for autos
Cheers
Chris
The cable isn't a problem to make if you have an original to work from (given the emanage case does not have a standard 9pin serial connection). If the interface on the e-manage is a serial 9pin as well its going to be a null-modem serial (not the normal kind) but one you can purchase from a computer store ready made. Haltech use this kind of connection on their ECU's.
  • 1 year later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
