OK I've had this weird thought that I should buy a VT/VX SS Commodore GenIII 6 speed. The reasons are I want something that I can tow a boat with next year when I buy one and something a little larger in size so I can seat more people.
I currently own an R33 GTST that I have had NO problems with at all. The only thing is the car will be 10 years old next year and as all cars this old it is showing its age.
Feel free to swing my decision away from the SS but keep in mind I want something NEW not pre 1997. Yes I could buy a 1991 R32 GTR :sly: but these cars are far too old. The engine will be tired and so will be the paint.
So basically I want something around the $25-28k, NEW, powerfull, towing capabilities and reliable.
HELP
https://www.sau.com.au/forums/topic/30016-help-me-i-want-to-buy-a-commodore/
Autech Stagea 260RS - no further discussion required :rolleyes:
fun for the WHOLE family! :)
Maybe not Autech, but possibly a Stagea.
oh and ur looking at figures of about 30% of GenIII's with mechanical problems, major problems.
Where are these statistics from?
10% of people know statistics 50% of statistics are made up on the spot :rolleyes:
Honestly, I don't think a VTii/VX SS is a bad idea.
Guest RedLineGTR
for about $25-28k u can find yourself (well i have seen advertised) a nice R34 Gtt (stock Form) going for about 28-29K the year is a 98 model so its not that old if your worried about it depends what u want to use it for. For that price you have to have a decent look around but these are the prices they are starting to go for.
QUOTE]
Id love an Autech Stagea too, its a pitty that they sell for more than R34 GTRs hey? If only i had a spare 100k lying around.
Im pretty sure there is only 1 Autech Stagea in Australia, the one that was in HPI a while back.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
