  • Replies 3.6k
Posted Images
Massa and Alonso look to have the speed. Cant see Button doing a brilliant job in his first race at McLaren whcih in the heat is going to require some driving around problems/setup. My dark horse for the only two that may knock off a Ferrari this weekend will be Rosberg and Webber
My tips for the weekend here:
1. Nico (He will break the drought, him and Schumi will lead 'Der Deutsches Arabiakorps' to victory in the desert!).
2. Nando.
3. Schumeister.
4. Captain chin.
5. Sebvet.
6. Massa.
7. Jenson.
8. Barry.
8. Der Hulk.
10. Captain nose.
Hammo will surely destroy either his tires, his brakes... Or both..
Guess What Guys.... Vettel is on top and Massa 2nd.. The new teams give them credit but they are not there yet... have to get another 5 secs of development...
and perhps Schumacher should have stayed home....My
wishes are Ferrari to rule with Alonso and Massa..
Well, thought i would be sneaky and get in with the first post for the 2010 season :nyaanyaa:
Overnight i read that Trulli and Heiki have been confirmed at Lotus. Not a bad driver line up for a new team looking to establish itself. At present based on the car's progress, the people and the drivers involved..i see Lotus perhaps being the strongest of the new teams.
Ermm... yeah of course. There'd be serious questions surrounding Nico's signing at Merc had Schuey came out in race 1 and been faster than him.
I'm really interested to see how the tyre choices (for the start of the GP) are going to effect the outcome, and no real surprise to me to see Vettel take pole
great to be back, but the lap is far too long. if it was an intersting circuit i would understand, but im becoming less and less a fan of this sand box
this year will be great. with red bull out in front early, it'll be great to see if they can stick with Mclaren and ferrari in the development race. they caught brawn last year, but i think with these two will be a different story. Mclaren stared off 2 seconds off the pace last year, now its around 5 tenths and we saw how strong they came on in the end of last year.
I think they'll get swollowed up later on up in the year, but they defintely in with a shout of at least one title
I agree, vettel burnt up his rears a couple of times last year, in not very long stints. with the extra weight and heat over there, I doubt he'll last long up the front.
will qualifying pace even mean anything about their race pace with all that extra weight?
To some extent it would, but it'd mostly come down to how well the drivers can preserve their tyres and fuel loads come the end of the race.
Anyone else notice Sutil is the only bloke in the top ten who qualified in the top ten on the hards??? Could possibly see Sutil on the podium... Those Force Indias certainly have a fair lick of top speed...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
