  • Replies 3.6k
Posted Images
Wow. This could play massively into Marks hands if the race starts dry or only lightly wet with his inters. I'm expecting a huge points haul for Red Bull... mechanicals permitting.
What a rollercoaster ride of a qualifying session.
Well that was a brilliant qualifying session if you ask me! :P So much for Webs can't drive in the wet hey... Plenty of world champs and former world champs spinning and putting it in the gravel.... :down:
Bring on the race!! :D
The real queston is, how many laps do they have to bag in order to be classified a full points result. Last year Webber was on for perhaps his first GP win or at least a podium when it was called to a halt. I hope when/if the weather comes tomorrow it doesnt rob Webs of a good points haul.
If its a wet race they can start on whatever tyre they want, ditto a dry race
Do they not do the 'start on the same tyres' thing if Q3 is wet?
Only in the dry this rule applies, for the prime/option tires.. Well I'm pretty sure anyway.
Oh, and COP THAT SH*T WEBBER HATERZ.. Bring it home P1 sonny!
Please Schu, show us some of that old wet weather magic!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
