  • Replies 3.6k
Posted Images
Hey, piss off! Chokehold is a bit of a fav of mine. He is on ESPN Star Sport a lot and he is a great guy, real car geek...and this hack of a bloke next to him who is "my nephew is so shit he needs me to start pumping his tyres full of hot air 10 years before he is even close to an F1 drive"
He has gone ok this year...all up I think he is done more then Di Gassi and Bullseye Senna
Well it looks as thought Ferrare have jumped the Macs for this race and Red Bull are still around the front two rows.
One thing is traffic at that place is shocking. The final times for the session were a little mixed because cars kept hitting traffic, but the Fezz and RBR all seemed to get 6 or so laps out of their softs in the 1:16-1:15 range.
Can't want for quali.....it looks like this track will be hard for overtaking but will be a close weekend
Vettel and Alonso are a class apart at present. Has anyone got anything in reserve for Q2 & Q3. Cant see Webz being quick enough in the first sector, he has been a few tenths off Vettel all weekend. Biggest casual gap i have observed between the two all year
Casual gap?
RBRs were on the hards and Alonso on the softs. Well thats what i could gather,. ESPN never tell you and its sometimes hard to pick up on screen
Great to see Williams in the top 10 and Rubens 6th! Interesting to see if RBR can lift the pace on the softs. At present Webz will be struggling to get on the front row....has not been able to turn the tyres on and seems to need the extra lap to get the time...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
